snakefood Posted May 20, 2008 Posted May 20, 2008 Hi, I am runing a small domain at home, XPSP2 Pro clients, Server 2003 standard server.The problem I have is this; twice so far I have been browsing the files on the server from the client, I have right clicked with the mouse and locked up the server's network access. Once this has happened, the server will not respond to pings from the client, although if i swap onto my kvm, I can access and use the server locally.I think I may have disabled WFP during setup; could this be causing the issue, or is it something else?HDD on server is a RAID1 Array, with shadow copy running. Gigabit nic's, plenty of ram both ends.Please post back with any ideas on what may be causing this, or if you need any more info.Thanks.Snakefood Quote
NIM Posted May 20, 2008 Posted May 20, 2008 Never heard of this, can you try with Standard Installation in VMWare and then test it, with WFP enabled by default.. Quote
