Posted December 9, 2024Dec 9 ImageGlass is a lightweight software application whose purpose is to help you view images in a clean and intuitive working environment. You are welcomed by a well-organized set of functions that enables you to perform most operations with minimal effort. You can switch to a full screen mode for a better focus on your work and view the thumbnails. It is important to mention that the tool offers support for context menu integration, so you can easily open the selected photos. Pictures can be uploaded into the working environment using the built-in browse button or “drag and drop” operations. ImageGlass gives you the possibility to zoom in or out of the image, go to the previous or next item from the selected directory, rotate items to different angles, lock the zoom ratio, refresh the current item, as well as play a slideshow. What’s more, you can convert the selected image to JPG, BMP, EMF, GIF, ICO, PNG, TIFF, WMF, or other file format, print items, upload photos on Facebook, change the background color, as well as set the maximum thumbnail file size. The tool lets you set the current image as your wallpaper, view file properties, move the items to the Recycle Bin or delete them from the hard drive, and rename items. During our testing we have noticed that ImageGlass carries out a task quickly and provides good image quality. It remains light on system resources, so the overall performance of the computer is not hampered. ImageGlass seems to be the right choice in case you are looking for a simple-to-use image viewer that comprises basic features for helping you navigate throughout your photo collection. Requirements Windows 10/11 64-bit, version 1809 or later .NET Desktop Runtime 8 (64-bit) WebView2 Runtime 64-bit v119.0.2151 or later Homepage : https://imageglass.org/ https://github.com/d2phap/ImageGlass Changelog : https://github.com/d2phap/ImageGlass/releases Silent installation Quote https://www.mediafire.com/file/0i462ejrg1xamud/ImageGlass+9.2.0.1208+x64+Silent+Install.rar/file https://www.upload.ee/files/17489981/ImageGlass_9.2.0.1208_x64_Silent_Install.rar.html https://mir.cr/T837SDEZ الكاتب
