Posted June 2, 200816 yr Windows Post-Install Wizard (WPI for short) is a hypertext application designed for giving users choice. While Windows XP offers many ways of customizing the setup process out of the box, its major drawback is the lack of being able to select which applications an end user may install. In the past, end users and administrators needed to either download the files manually, or create overly complex scripts that could only be used once. WPI allows you to create one image, which can then be custom configured, and optionally, automated, so that end users can install any applications that have been configured into WPI. New Windows Style Theme: New Server Style Theme: New Vista Style Theme: Here is the 6.5.1 changelog:6.5.1 Updates - Released June 4, 2008Fixed the audioplayer in the installer modeFixed the missing "Other" category boxAdded german manualupdated a couple of minor other problems.6.5 Updates - Released June 1, 2008-------------------------------------------------------------------------------* Added command getOSlang(). Returns a three letter code: ENU, FRA, ITA, etc.* Fixed bug with default options not saving properly. Now done before Optionswizard is opened, and again when opened.* Took tips back out of Options and Config. Maybe temporarily.* Fixed a bug in excludorIsChecked().* Kel wrote a new manual.* Added Finnish local text.* Updated all themes to be v6.5 minimum and consistant code.* Took View Source out of all themes.* sadicq updated USSF to handle the 10 commands in Config.* Bernard DUJARDIN (t4user) coded some major enhancements: * Added a check before closing if made any changes in the Options or Config. * Put tips back in Options and Config. * Foreign language check. * Fixed bug in Sort Order box and localized it. * CreateTab() and LocalizeText() updates. * Tool tip code update to work in Optons and Config properly.A huge thank you for this code.* Fixed a potential bug in timers.js that could get the timer startedtwice and not stop when supposed to.* Updated themes Server, Windows, Vista, and XPize Dark to new code callSetupWPI().* WPI now calculates how many items can be in a column. You can customize it in wpi.htm in the theme folder. Un-comment and change the line:// maxentries += 2; // Set your custom number of items per column* Fixed a bug in the theme check in Options wizard.* Added a volume control slider in Options -> Audio Player.* Added more screen resolutions.* Localized some texts in Options and Config wizards.* Tweaked the Options tab to have the gadgets size themselves better.* Added Window tab to Options. You can now specify how to open the WPI window:with or without a border, gadgets, etc. NOTE: These settings are global andwill affect all themes.* Fixed the Reg Before/After quotes bug. For sure this time!* Fixed some miscellaneous "bugs" in the installer.* In WPI_Log.txt it now shows the number of items being installed, and thetotal number of commands in those items.Notes and ExtrasSuggested disk folder layout:With the above folder layout all your config entries should read like:%wpipath%\Install\Blah.exe]Here is a small tutorial on how to add an app to WPI!Ok this is a sample (Very simple) configuration for CCleaner (A.K.A Crap Cleaner) This assumes you have all of the WPI files either in the WPI folder at the root of your Windows cd or all of the WPI folders (Common, Graphics, WPIScripts, Tools, Install and Themes) and the file WPI.hta at the root of your cd.Remember this is just the most basic and required entries for a program!#1 Download the app and place it in the WPI\Install Folder. (CCleaner.exe in this example) #2 Run WPI.hta and click on the "Config" button\Icon area. #3 Choose the button at the very top above the config section that says "Add"#4 Enter in the name section "CCleaner" <--No quotes! Then click on any other section of the config area to activate the rest of the wizard.#5 You will notice the Unique ID section gets automatically configured for you.#6 All apps are selected to be installed by default right from the start so if you don't want it selected by default you must uncheck this box. Also you can decide if you want this app to be a "Forced Install" or not. #7 Choose a category for your app to be displayed in. If you want the app to be displayed in a category you don?t see simply chose other and a box will appear that will allow the entry of you choice.#8 In the Command 1 section click on the little folder icon and browse to the WPI\Install folder and select the CCleaner.exe installer, this will place the full path to the installer in the commandline.#9 Add the necessary switches for the program to run silently i.e. "%wpipath%\Install\CCleaner.exe" /s (This can be easily done for most standard apps by simply clicking on the USSF button on the far right of the commandline.)#10 Select the Save and then the Exit buttons and you have now configured your first app!Afterwards you can use an app like nLite, vLite, CDImageGUI or the Makeiso program included in the tools archive to make your CD w\WPI bootable again. MakeIso.exe = Adds "make bootable iso" to the right click menu of folders. It is a silent installer so DO NOT click on it 50x a simple double click is all that is need to install it. It can be uninstalled from the add\remove programs menu! Just go to the "Source" folder (The one that contains I386 and WPI) and right click then select MakeISO... _____________________________________________________________________I have seperated the tools out from the main archive. You can download the tools here:Tools archive.Contents of the tools archive:WPI Config ListerCDSwitchMakeISO.exe3 Custom themes for CDSwitchautorun.inf <-- Updated and fixedWPI.ico New icon thanks to WolfX2TaskKillS.exe from sadicqTaskKillS InstructionsCleanup.exe (Deletes ALL icons from the desktop)Reboot.exe (Dialog box that will reboot in 60 sec unless cancel is pressed)_____________________________________________________________________Here is a quick start package that will set your windows disk up to use WPI after the desktop loads.This is for use with all versions of Windows 2000, XP and 2003!To make use of this archive all you need to do is unRAR it and place the %oem% folder beside the I386 and WPI folders.Post $OEM$ Folder (The forum is messing up this link so copy www.wpiw.net/downloads/Post_$oem$.rar )Contents of the Post %OEM% archive:cmdlines.txtRunWPI.inf_______________________________________________________________________Here is a quick start package that will set your windows disk up to use WPI with runonceex.This is for use with all versions of Windows 2000, XP and 2003!To make use of this archive all you need to do is unRAR it and place the %oem% folder beside the I386 and WPI folders.$OEM$ Folder (The forum is messing up this link so copy www.wpiw.net/downloads/$oem$.rar )Contents of the %OEM% archive:cmdlines.txtRunWPI.exe (Sets the runonceex and MCE themeing entries used for WPI)_______________________________________________________________________NEW!!!An $OEM%\WPI folder that sets up your WPI for RunOnceEx with the official Zune Microsoft Theme!$OEM$-Zune Folder (The forum is messing up this link so copy www.wpiw.net/downloads/$oem$-zune.rar )Contents of the %OEM%-Zune archive:cmdlines.txtRunWPI_Zune.exeUse is as the same as the one above..._______________________________________________________________________This is for use with all versions of Windows Vista!To make use of this archive all you need to do is unRAR it and place the Sources folder at the root of your CD.Sources Folder.Contents of the Sources archive:setupcomplete.cmd (This needs to be several folders deep so I preset the folders for you)________________________________________________________1978 .png images for your pleasure to use in your tooltips or whatever!PNG Collection.________________________________________________________Themes are now hosted on WPI.net!!!Theme page!Please remember and donate!
July 2, 200816 yr I've a little problem and I am sorry if it seems easy for you, but I've just downloaded the WPI and added all applications I want to install folder and did the config file as fine. Then Iconfig.zip Edited July 2, 200816 yr by MGadAllah
July 3, 200816 yr Known bug will be fixed sooon....Ok, Does there is an earlier version still working?Thanks
July 3, 200816 yr Thanks a lot Kel. Does there is any one of them you are recommending more? or in other words which version you are recommending mate!?Thanks Edited July 3, 200816 yr by MGadAllah
