boxshot_txt2pdf.gifText to pdf (txt2pdf) v2. 2
Ap Text To PDF ( text2pdf ,txt2pdf ) is a program to convert ASCII texts into PDF format with a minimum loss of formatting information. Support command line, batch convert, encryption, page orientation, font setting etc.
Text to PDF Features
Searchable text base on the generated PDF files
Force font size, font name, font color and paper size
Ability to process reports that do not contain form feeds
Acrobat compatible encryption and rights protection
Supports command line operation (for manual use or inclusion in scripts)
Extracts page alignment information
Supports drag and drop files
Batch convert text files to PDF files
Password protection for PDF files with 40 or 128 bit encryption
Set file permissions to restrict printing, copying, and future modifications to the document
Supports page rotation (angle equal: 0,90,180,270)
Supports page orientation (Portrait and Landscape)
Auto open PDF file after creation
Does NOT need Adobe Acrobat software
Append to existing PDFs.
Optimized to increase speed
Command line features
The Text to PDF Command Line program provides a regular console interface to Text To PDF functionality.
It includes all of the features in Text To PDF.
It can simple to use like a DOS Command Line application
Download
md5:F623ED05FEBEB595D1BF4E47F45C4E3A
Website
