大†Shinegumi†大 Posted January 18 Posted January 18 (edited) Microsoft Edge 133 is now rolling out globally, and it ships with several improvements, including a new scareware blocker feature. In addition, Microsoft is updating the backend of the Downloads UI with performance improvements. For those unaware, "scareware scams" are also known as tech support scams and they trick victims with alarming web pages claiming their device is infected. Scammers then pressure them to call a fake support number and gain remote access. Microsoft has been testing an AI-powered scareware blocker feature for a while now. Starting with version 133, you can finally turn it on from Edge's Settings. Scareware blocker settings Unlike Defender SmartScreen, which is designed to protect users as well, Edge's new AI/ML-based scareware blocker works in real-time because it understands the content on the web page. Scareware blocker warning "The model uses computer vision to compare full screen pages to thousands of sample scams that the scam-fighting community shared with us. The model runs locally, without saving or sending images to the cloud," Microsoft noted in a blog post. In addition to the scareware blocker, Edge's downloads UI has now been rewritten in WebUI 2.0, which means faster performance. With WebUI 2.0, Microsoft is building an entirely new markup-first architecture that minimizes the size of code and the amount of JavaScript code that runs during the initialization path of the UI. This new internal UI architecture is more modular and allows Microsoft to ship new browser features faster. After Edge 133, Downloads UI should load faster, but you'll not notice any UI changes. To try the Scareware blocker and faster Downloads UI, update Edge to version 133 from Settings > About. What is Microsoft Edge WebView2 Runtime? Microsoft Edge WebView2 is a runtime installation used to provide web-based features in Microsoft 365 desktop apps that Microsoft began installing on Windows devices earlier this year. WebView2 uses Microsoft Edge as the rendering engine. In Windows 11, the component is installed on the system by default. On earlier versions of Windows, it is automatically installed for users with modern versions of Microsoft Office for the specific purpose of running Office applications and the components built into the applications, built on top of web frameworks. For PC users looking to take advantage of new or improved Office features or add-ins that depend on WebView2, they do not require any user input/action; as soon as WebView2 is available on the device, the component will be installed automatically. Regarding updates, WebView2 Runtime uses its own automatic update process, separate from the update channel used by Microsoft 365 Apps, to keep WebView2 up to date with the latest security and reliability updates. Silent installation Windows 11/10 Edge with WebView2 Quote https://www.mediafire.com/file/p5j049xfls34i2h/Microsoft+Edge-WebView2+Runtime+133.0.3065.82+AIO+Silent+Install.7z/file https://mir.cr/72SVQTMU Windows 7/8 تثبيت صامت Silent installation Microsoft Edge-WebView2 Runtime 109.0.1518.140 Aio Win 7 Silent Install Edge with WebView2 Quote https://www.mediafire.com/file/3uckk412kgsd9m3/Microsoft+Edge-WebView2+Runtime+109.0.1518.140+Aio+Win+7+Silent+Install.7z/file https://mir.cr/0EUVSWWV Edited 11 hours ago by 大†Shinegumi†大 Quote
大†Shinegumi†大 Posted Friday at 01:27 AM Author Posted Friday at 01:27 AM Changes in Edge 133.0.3065.69 (2025-02-14): Quote
大†Shinegumi†大 Posted 11 hours ago Author Posted 11 hours ago Changes in Edge 133.0.3065.82 (2025-02-21): Quote
