AutoSmall Ver.3.1
Description: AutoSmall is a Desktop-icon-stylechanger.
It counts the number of Desktop-icons and when the number is over the settled one,then
It changes Desktop-icon-Style to small-icon.
This Addon Place Autosmall.exe in %allusersprofile%\Start Menu\Programs\Startup
And no shortcut, for Uninstall delete Autosmall.exe from%allusersprofile%\Start Menu\Programs\Startup
and if donot use addon extract cab file and use anywhere with Dclick
Mona_Autosmal_Addon.cab size:11.6kb
md5:3DA48C367D1EDA32D4BC492AC236F5A2
Website
Edited by mona
I tried this on a working system, all is fine but I dint like that "notepad" display at every windows start-up. can you remove this please?
Thank you
Thank you
not remove it for MC FILE ITS Configuration Settings YOU can RUN PROGRAM FROM Desktop
Edited by mona
Ok. I wanted to test it, so I extracted it on the desktop and installed it from there. but I don't think that is the problem..or?
Cool! One question though - I read somewhere how to enable this on an existing install, but it was said this tweak caused a bug with folder view setting change, is this fixed in the addon version?
  • 1 year later...
