iTunes is the easiest way to organize and enjoy the music, movies, TV shows, apps, and books you already own, and shop for the ones you want. You can even listen to free streaming radio stations with iTunes Radio.
iTunes is an advanced application that is not only a very good media player, but also an excellent iPod and iPhone manager. Simplicity is perhaps the most appropriate word that can sum up its overall appearance and usability.
iTunes lets you do whatever you want with your gadgets, including backup, sync, contact management, and most importantly, install apps from the Apple Store. IPhone owners surely know that in order to purchase and install applications hosted on the iTunes Store, they need the downloadable application that provides the necessary environment to purchase software safely.
The app will play your videos and music in an instant, help you organize playlists and library items. Other than that, iTunes has all the features you'd expect in a media player, plus something special: you can easily subscribe to podcasts, TV shows, and other types of content, and each of these files are automatically delivered to your computer as soon as may be possible. They're available.
The 'iTunes Backup' feature is quite useful and will allow you to save your library to CD or DVD. You can back up only purchases from the Store or all content, as desired. There is also an option that allows you to perform an incremental backup, which means that only items added or modified since the last backup will be updated.
With iTunes, everything is close at hand, and seamless integration with external devices like iPods and iPhones lets you manage everything with ease. Of course, you can also use it as a media player, but you'd better give it a try to see for yourself what it can actually do for you.
Silent installation
Download
iTunes 12.13.7.1 X64 Silent Install
https://www.mediafire.com/file/k4vimxkrpnr69bg/Apple+iTunes+12.13.7.1+x64+Silent+Install.rar/file
https://mir.cr/IVVC6PKG
iTunes 12.13.7.1 X86 Silent Install
https://www.mediafire.com/file/mjcksbvtwetemnd/Apple+iTunes+12.13.7.1+x86+Silent+Install.rar/file
https://mir.cr/FF3E6JYB
Apple iTunes
Silent Install Version for Windows 7 -8.1
https://www.mediafire.com/file/grq3lt7nmo9tmzj/Apple.iTunes.12.4.3.ОС.w8.ОС.w7.Silent.Install.rar/file
Edited by T3rM1nat0Rr3
  • T3rM1nat0Rr3 changed the title to Apple iTunes 12.13.7.1 x86 / x64 Silent Multilingual
