March 8Mar 8 What's new in Edge 143HighlightsLocal network accessLocal network access in Microsoft Edge is a new security feature that limits websites' ability to send requests to servers on your local network. When a website attempts to connect, Microsoft Edge will display a prompt asking you to grant or deny permission. This protects privacy and security while maintaining compatibility with modern web standards. Websites' ability to request this permission from users is limited to secure contexts. This feature is enabled by default starting with Microsoft Edge 143. Enterprise administrators can configure local network access policies. Details can be found here.AdvertisеmentNew software backend for WebGL.Microsoft Edge on Windows on devices without a physical graphics processing unit (GPU) will use the Windows Advanced Rasterization Platform (WARP) rasterizer for WebGL workloads. Previous versions used SwiftShader, which is no longer supported. This is most relevant for headless mode (running the browser without a GUI for automating tasks) and virtual machines. On non-Windows platforms, a physical GPU will be required for WebGL to work. This change is planned for the stable release of Microsoft Edge 144. Administrators can test the new behavior using preview builds of Microsoft Edge Canary, Dev, or Beta. For more information, follow this link.Changes and improvementsUndo/Redo for PDF annotations. In the new Windows PDF viewer, users can now undo or redo actions with annotations, such as highlighting or inking.Added protection against malicious extensions installed from third-party sources. Microsoft Edge will now detect and revoke malicious extensions installed from third-party sources.Note: This change is rolling out in stages, so you may not see the changes on your device right now.Improved diagnostic data collection for customer support. Organizations that can't use the "Send Feedback" option in Microsoft Edge can now use a new export feature. A keyboard shortcut Alt + Shift + I will open a new feedback dialog where users can select "Diagnostic Data." A pop-up window will then appear with an "Export" button in the upper right corner. This allows you to save diagnostic information for support requests.Removing the Mini Menu from Microsoft Edge for Mac. The Mini Menu was triggered on websites and in PDFs when text was selected and contained basic actions like copying and intelligent actions like looking up word definitions. This feature was removed starting in Microsoft Edge 143 for Mac. The QuickSearchShowMiniMenu policy was also deprecated starting in Microsoft Edge 143.Tab Search. This feature helps users stay organized by allowing them to quickly find and reopen recently closed tabs, as well as search all open tabs in a single window. This menu also allows you to enable vertical tabs, access the AI-powered "Tab Organization" feature, and create workspaces.New policiesLocalNetworkAccessRestrictionsTemporaryOptOut - Determines whether local network access restrictions should be temporarily opted out.RAMResourceControlsEnabled - Enables RAM resource control.ShareBrowsingHistoryWithCopilotSearchAllowed - Allows sharing of customer-approved browsing history with Microsoft 365 Copilot search.What is Microsoft Edge WebView2 Runtime?Microsoft Edge WebView2 is a runtime installation used to provide web-based features in Microsoft 365 desktop apps that Microsoft began installing on Windows devices earlier this year. WebView2 uses Microsoft Edge as the rendering engine.In Windows 11, the component is installed on the system by default. On earlier versions of Windows, it is automatically installed for users with modern versions of Microsoft Office for the specific purpose of running Office applications and the components built into the applications, built on top of web frameworks.For PC users looking to take advantage of new or improved Office features or add-ins that depend on WebView2, they do not require any user input/action; as soon as WebView2 is available on the device, the component will be installed automatically. Regarding updates, WebView2 Runtime uses its own automatic update process, separate from the update channel used by Microsoft 365 Apps, to keep WebView2 up to date with the latest security and reliability updates.Silent installationWindows 11/10Edge with WebView2تم دمج متصفح Edge-WebView2 مع بعضها البعض في ملف واحد https://www.mediafire.com/file/0m4es53k629s7ae/Microsoft+Edge-WebView2+Runtime+143.0.3650.66+AIO+Silent+Install.7z/filehttps://seyarabata.com/69333f2dcdc04 Windows 7/8تثبيت صامتSilent installationMicrosoft Edge-WebView2 Runtime 109.0.1518.140 Aio Win 7 Silent InstallEdge with WebView2https://www.mediafire.com/file/3uckk412kgsd9m3/Microsoft+Edge-WebView2+Runtime+109.0.1518.140+Aio+Win+7+Silent+Install.7z/filehttps://mir.cr/0EUVSWWV Edited December 6Dec 6 by T3rM1nat0Rr3
June 28Jun 28 Author Version 138.0.3351.55: June 26, 2025Fixed various bugs and performance issues, feature updates, policy updates, and web platform release notes.Stable channel security updates are listed here.FixesFixed an issue which caused WebDriver automation to fail in Microsoft Edge versions 133 and later.Fixed an issue where re-enabled <textarea> elements remained noneditable. This issue affected activating a role assignment in Privileged Identity Management.Feature updatesUse Primary work profile as default profile to open external links. Microsoft Edge currently opens external links using the “Last Used” profile by default. While for enterprise users, the Primary Work Profile (signed in with a Microsoft Entra ID for enrolling the device) is normally the best profile for opening external links. With this feature, for Windows, Edge checks if the Primary Work Profile exists and makes it the default profile for opening external links if available. For Mac and Linux, if only one work profile signed in with a Microsoft Entra ID account is found, it’s treated as the Primary Work Profile. Admins can control availability to this feature using the EdgeOpenExternalLinksWithPrimaryWorkProfileEnabled policy. Note: This is a controlled feature rollout. If you don't see this feature, check back as we continue our rollout.New Autofill Personal Information Settings Configuration. A web form field collection consent toggle will be available in Autofill settings (edge://settings/autofill/personalInfo). This allows users to consent to Microsoft Edge collecting web form field labels (for example, "First Name," "Email") to improve Autofill suggestion accuracy. Only field labels are collected and not user-entered data. The web field labels are stored securely per Microsoft's privacy standards.This new setting is manageable via existing policies in Autofill (for example, AutofillAddressEnabled, EdgeAutofillMlEnabled. AutofillAddressEnabled) is the parent setting for (EdgeAutofillMlEnabled)[/deployedge/microsoft-edge-browser-policies/edgeautofillmlenabled]. The EdgeAutofillMlEnabled policy is the parent of this new setting, thus turning off the EdgeAutofillMlEnabled policy turns off this setting. Note: These features are a controlled feature rollout. If you don't see these features, check back as we continue our rollout.AI-powered History search. Enhanced search finds sites in your History even when you use a synonym, phrase, or typo. After this feature is turned on, sites you visit will be shown in enhanced history search results. An on-device model is trained using your data, which never leaves your device and is never sent to Microsoft. Admins can control availability to this feature using the EdgeHistoryAISearchEnabled policy. Note: This is a controlled feature rollout. If you don't see this feature, check back as we continue our rollout.Microsoft 365 Copilot Chat Summarization in Microsoft Edge Context Menu. Microsoft Edge is introducing a Microsoft 365 Copilot Chat summarization menu item to our context menu. This feature helps users quickly unpack and ask questions about their open page. Note: This feature is a controlled feature rollout. If you don't see this feature, check back as we continue our rollout.Improvements to surfacing performance notifications. Microsoft Edge is making improvements to how users can learn about and improve their browser's responsiveness. Performance and Extensions Detector notifications may appear in the Settings and more menu when Edge's performance slows. Note: This feature is a controlled feature rollout. If you don't see this feature, check back as we continue our rollout.Copilot on the Microsoft Edge New Tab Page (NTP). Starting at the end of May 2025, users may see suggested work and productivity-related Copilot prompts by their search box on the NTP page. Also, users may see the Copilot icon in their search box allowing them to click on the icon to send their current search query to Copilot. The Copilot admin policy NewTabPageBingChatEnabled continues to be enforced and will still apply. NTP changes are rolled out to all Microsoft Edge release channels. Note: These features are a controlled feature rollout. If you don't see these features, check back as we continue our rollout.Adding support for viewing Sensitivity labels applied to a Microsoft Information Protection (MIP) Protected PDF. Enterprise customers can view sensitivity labels applied to MIP protected PDF to be well informed of the data classification to enable them to handle such sensitive documents. This change is available in the new Microsoft Edge built-in PDF reader. Note: This is a controlled feature rollout. If you don't see this feature, check back as we continue our rollout.Policy updatesNew policiesBuiltInAIAPIsEnabled - Allow pages to use the built-in AI APIsEdgeHistoryAISearchEnabled - Control access to AI-enhanced search in HistoryEdgeOpenExternalLinksWithPrimaryWorkProfileEnabled - Use Primary Work Profile as default to open external linkLocalNetworkAccessRestrictionsEnabled - Specifies whether to block requests from public websitesPrefetchWithServiceWorkerEnabled - Allow SpeculationRules prefetch for ServiceWorker-controlled URLsTLS13EarlyDataEnabled - Control whether TLS 1.3 Early Data is enabled in Microsoft EdgeObsoleted policiesInsecurePrivateNetworkRequestsAllowed - Specifies whether to allow websites to make requests to any network endpoint in an insecure manner (obsolete)InsecurePrivateNetworkRequestsAllowedForUrls - Allow the listed sites to make requests to more-private network endpoints from in an insecure manner (obsolete)PrivateNetworkAccessRestrictionsEnabled - Specifies whether to apply restrictions to requests to more private network endpoints (obsolete)ZstdContentEncodingEnabled - Enable zstd content encoding support (obsolete)NoteFor the latest web platform features and updates, see Microsoft Edge 138 web platform release notes (June 2025)
July 3Jul 3 Author Version 138.0.3351.65: July 1, 2025Fixed various bugs and performance issues for Stable Channel.Stable channel security updates are listed here.
July 8Jul 8 Author Version 138.0.3351.77: July 7, 2025Fixed various bugs and performance issues and feature updates.FixesReverted a change that caused audio issues when playing videos with AAC audio on certain websites. This is planned to be a temporary mitigation, as the root cause is a bug in outdated versions of the HLS.js library used by websites. Affected site owners are encouraged to update to a newer version of HLS.js to ensure compatibility.Feature UpdatesFind on Page in Microsoft Edge for Business will soon be integrated with Microsoft 365 Copilot Chat. Microsoft Edge for Business is introducing Microsoft 365 Copilot Chat to Find on Page (CTRL+F). This feature seeks to help users more easily find relevant content and save time.
July 17Jul 17 Author Version 138.0.3351.95: July 16, 2025Fixed various bugs, feature updates, and performance issues for Stable Channel.Stable channel security updates are listed here.Feature updatesMicrosoft Edge policies to manage Shadow IT. This feature restricts access to non-Microsoft Generative AI tools using Edge policies. Using the WebContentFilteringBlockedCategories policy, admins can restrict access to other LLMs (except Copilot Chat) along with all browsers (except Microsoft Edge). This helps admins address the shadow IT problem, which is the use of Gen AI tools without oversight of IT admins in the organization. Some of these Gen AI apps can cause data loss and don't comply with the organization's security policies.Version 138.0.3351.83: July 10, 2025
August 1Aug 1 Author Version 138.0.3351.121: July 31, 2025Fixed various bugs and performance issues for Stable ChannelStable channel security updates are listed here.
August 10Aug 10 Author These release notes provide information about new features and nonsecurity updates that are included in the Microsoft Edge Stable Channel.All the security updates are listed in Release notes for Microsoft Edge Security Updates.Archived release notes for Microsoft Edge Stable Channel are located in Archived release notes for Microsoft Edge Stable Channel.To understand Microsoft Edge channels, see the Overview of the Microsoft Edge channels.NoteFor the Stable Channel, updates roll out progressively over one or more days. To learn more, see Progressive rollouts for Microsoft Edge updates.Microsoft Edge Web Platform constantly evolves to improve user experience, security, and privacy. To learn more, see Site compatibility-impacting changes coming to Microsoft Edge.Version 139.0.3405.86: August 7, 2025Fixed various bugs and performance issues, feature updates, policy updates, and web platform release notes.Stable channel security updates are listed here.FixesFixed an issue where MIP-protected PDF files from different sovereign cloud environments (including GCCH) failed to open and instead displayed the error message: “Need permissions. Contact the owner of the file to give you permissions.”Fixed an issue, which affected IE mode, including errors when displaying PDF files, running Java applets, and showing the Information Bar in IE mode.Improved reliabilityFixed a browser crash that occurred on first launch when the BrowserSignin policy was enabled and configured to "Force (2) = Force users to sign-in to use the browser (all profiles)."Feature updatesOpen external links in another profile when recommended by external applications. When Microsoft Edge is set as the default browser to open external links from applications, Microsoft Edge must determine which profile to open the links. Users can control which profile to use through the “Default profile for external links” setting. Applications such as Microsoft Teams or Outlook can also recommend a profile for the links. Currently, the user setting is prioritized over application recommendations. With this feature, the application recommended profile is given priority, instead of the profile selected in the setting. Admins can control the availability of the feature using the EdgeOpenExternalLinksWithAppSpecifiedProfile policy. Note: This is a controlled feature rollout. If you don't see this feature, check back as we continue our rollout.Changes to Wallet in Microsoft Edge. Wallet is being phased out to support a streamlined experience within Microsoft Edge. This affects the Wallet feature in Settings and the Mini Wallet found by clicking the profile icon in the top banner. Users are directed to the new Passwords, Payment, and Personal Information management experience in Settings. Also, a new Password management experience is available in Settings. For more information, see Changes to Wallet in Microsoft Edge. Note: This is a controlled feature rollout. If you don't see this feature, check back as we continue our rollout.Introducing a new policy that can enable/disable Microsoft 365 Copilot Chat in Edge for Business from showing in the toolbar. Edge for Business now has a dedicated policy, Microsoft365CopilotChatIconEnabled, to enable and disable Copilot in Edge from showing in the Edge toolbar. When both this policy and HubsSidebarEnabled are configured, this policy takes precedence in determining whether Copilot appears in the toolbar. If this policy isn't configured and HubsSidebarEnabled is disabled, Copilot will remain hidden. In a future release, this policy is the sole control for managing Copilot's visibility in the toolbar.Real-time notifications for compromised passwords. Microsoft Edge is integrating an in-context password breach notification system. This feature proactively informs users if their saved login credentials have been compromised in known data breaches, enabling them to take immediate action to secure their accounts. Admins can control availability to this feature using the PasswordMonitorAllowed policy. Note: This is a controlled feature rollout. If you don't see this feature, check back as we continue our rollout.Edge Settings Improvements. Edge Settings is migrating to WebUI2 to boost page responsiveness and introducing a series of minor visual and content upgrades to improve overall usability and utility. This includes optimizing for concise wording of individual settings, simplifying the number of pages and reorganizing content, and creating a cohesive user interface.New Autofill Personal Information Settings Configuration. A web form field collection consent toggle will be available in Autofill settings (edge://settings/autofill/personalInfo). This allows users to consent to Microsoft Edge collecting web form field labels (e.g., "First Name," "Email") to improve Autofill suggestion accuracy. Only field labels are collected and not user-entered data. The web field labels are stored securely per Microsoft's privacy standards.This new setting is manageable via existing policies in Autofill (e.g., AutofillAddressEnabled), EdgeAutofillMlEnabled. AutofillAddressEnabledis the parent setting forEdgeAutofillMlEnabled. The EdgeAutofillMlEnabled policy is the parent of this new setting, thus turning off the EdgeAutofillMlEnabled policy turns off this setting.Web AI APIs for prompt and writing assistance. Microsoft Edge now implements the Writing Assistance APIs and the Prompt API(for Edge extensions) with a local language model, Phi-4-mini, that is built into the browser. These easy-to-use JavaScript APIs are made available via Edge flags (set to Enabled, by default only for the Summarizer and Prompt API for extensions) so that sites and extensions can apply AI capabilities on the web. The small language model is downloaded as the first time any of these APIs is used and later shared across all domains, serving local AI use-cases with reduced cost, network independence, and increased privacy (since data input to the model doesn't leave the user’s device). Admins can control the availability of these APIs via the GenAILocalFoundationalModelSettings policy. These APIs are currently not implemented in China. Read the announcement here, and feel free to provide feedback.Enhancements to Performance and Secure network. Browser essentials is now separated into two distinct experiences (Performance and Secure Network) - both available from the Settings and more menu (“…” on the menu bar).Reset Microsoft Edge enterprise sync. For users having problems syncing browsing data across other signed-in devices, they can reset sync data from the Microsoft servers via Edge Settings edge://settings/profiles/sync/reset. This option should only be used if the sync data is available on one of the user's devices or if they want to delete all sync data from the servers. Note: In Microsoft Edge 139, reset sync is enabled for users encountering a "No permissions" MIP error and in Microsoft Edge 140, reset sync is enabled for users encountering a "Service disabled" MIP error.Update to Microsoft AutoUpdate policy. The MAUEnabled policy allowed admins to continue using Microsoft AutoUpdate on macOS. Since Microsoft Edge now uses EdgeUpdate, the MAUEnabled policy is planned to be obsoleted in Microsoft Edge version 140.Policy updatesNew policiesEdgeOpenExternalLinksWithAppSpecifiedProfile - Prioritize App specified profile to open external linksEnableUnsafeSwiftShader - Allow software WebGL fallback using SwiftShaderMandatoryExtensionsForInPrivateNavigation - Specify extensions users must allow in order to navigate using InPrivate modeMicrosoft365CopilotChatIconEnabled - Control whether Microsoft 365 Copilot Chat shows in the Microsoft Edge for Business toolbarOnSecurityEventEnterpriseConnector - Configuration policy for Microsoft Edge for Business Reporting ConnectorsObsoleted policiesKeyboardFocusableScrollersEnabled - Enable keyboard focusable scrollers (obsolete)SelectParserRelaxationEnabled - Controls whether the new HTML parser behavior for the SELECT element is enabled (obsolete)NoteFor the latest web platform features and updates, see Microsoft Edge 139 web platform release notes (August 2025)
August 17Aug 17 Author Version 139.0.3405.102: August 15, 2025Fixed various bugs and performance issues for Stable ChannelStable channel security updates are listed here.
August 26Aug 26 Author 1https://learn.microsoft.com/en-us/deployedge/microsoft-edge-relnote-stable-channel
September 14Sep 14 Author Version 140.0.3485.66: September 11, 2025Fixed various bugs, and performance issues.Stable channel security updates are listed here.
September 20Sep 20 Author Version 140.0.3485.81: September 19, 2025Fixed various bugs, fixes and performance issues.Stable channel security updates are listed here.FixesFixed an issue where a transparent overlay appeared on the address bar when in IE mode.
September 27Sep 27 Author Version 140.0.3485.94: September 25, 2025Fixed various bugs and performance issues and feature updates.Stable channel security updates are listed here.Feature updatesData Loss Prevention - New inline data protection in Edge for Business for unmanaged Windows and macOS devices. When using Microsoft Edge for Business as the secure enterprise browser, Admins in Purview DLP can now configure policies that apply protections directly in the Edge browser that target scenarios where users on unmanaged (or BYO) devices are sharing data to or exfiltrating data from org-managed cloud apps (apps, which use Entra authentication for user sign-in). For more information, see Learn about Data Loss Prevention for Cloud Apps in Edge for Business, Help Prevent Users from Sharing Sensitive Info with Cloud Apps in Edge for Business, and Data Loss Prevention policy reference.
October 4Oct 4 Author Version 141.0.3537.57 October 2, 2025Fixed various bugs and performance issues, feature updates, policy updates, and web platform release notes.Stable channel security updates are listed here.AnnouncementsNew PDF Viewer Enabled by Default in Microsoft Edge. In Microsoft Edge Stable version 141, the Adobe-powered PDF viewer is now the default experience for enterprise users on Windows. Migration will occur on a phased rollout and will continue over the next few months. This change enhances performance, accessibility, and compatibility, and introduces exclusive enterprise features. Admins can manage the experience using the NewPDFReaderEnabled policy which controls the default viewer in Edge for Windows or the NewPDFReaderWebView2List policy which controls viewer behavior in WebView2 apps. For more information, see the FAQ page. Also, tenant admins can find additional details in the Message Center section of the Microsoft 365 Admin Center under MC1154300.Local Network Access. Local Network Access in Microsoft Edge is a security feature that restricts a website’s ability to send requests to servers on your local network. When a website tries to connect, Microsoft Edge shows a prompt asking you to grant or deny permission. This protects privacy and security while maintaining compatibility with modern web standards. The ability of a website to request this permission from users is restricted to secure contexts. This feature is currently disabled by default in Microsoft Edge, but the default state will change starting in Edge 143. Enterprise administrators can configure Local Network Access policies. More information for users and administrators can be found here: Control a website’s access to the local network in Microsoft Edge.FixesFixed an issue where a UIA (UI Automation) element recursively referenced itself as a child, causing timeouts and memory issues.Feature UpdatesReal-time video translation. Real-time video translation. If you're learning a new language, or just like to watch foreign videos with subtitles in your preferred language, Microsoft Edge can help. With real-time video translation in Edge, you can watch videos in a different language with translated audio dub. Feature availability and functionality may vary by device type, hardware configuration (minimum 12 GB RAM and 4-core CPU), region, and platform. Availability is limited to select markets. For more information, see Real-time video translation | Microsoft Edge. Admins can control availability to this feature using the LiveVideoTranslationEnabled policy.Policy to enable/disable Microsoft 365 Copilot Chat in Edge for Business from showing in the toolbar. Edge for Business now has a dedicated policy, Microsoft365CopilotChatIconEnabled, to enable and disable Copilot in Edge from showing in the Edge toolbar. This policy is the sole control for managing Copilot's visibility in the toolbar and the HubsSidebarEnabledd policy will no longer control the visibility of the Copilot toolbar button.Tab preview on hover policy. The ShowTabPreviewEnabled policy lets administrators control whether Microsoft Edge displays a preview of the tab content when the user hovers over a tab. If the policy is enabled or not configured, Microsoft Edge shows a tab preview when the user hovers over a tab.Update to "Clear Browsing Data on Close" behavior. The "Clear browsing data on close" setting (edge://settings/privacy/clearBrowsingData/clearOnClose) no longer supports automatic deletion of Passwords and Autofill data. The Passwords and Autofill form data toggles have been removed from the Settings page. Manual deletion of Passwords and Autofill remains possible via the "Delete browsing data" settings. The other data types (Browsing history, Download history, Cookies, Cached images, and Site permissions) are unaffected and can still be cleared on exit. This update does not impact enterprise policies, which continue to function as expected.Policy updatesNew policiesLiveVideoTranslationEnabled - Allows users to translate videos to different languagesOriginKeyedProcessesEnabled - Enable origin-keyed process isolation for improved securityRelaunchFastIfOutdated - Relaunch browser quickly when the current version is outdatedShowTabPreviewEnabled - Enable tab preview on hoverWebRtcPostQuantumKeyAgreement - Enable post-quantum key agreement for WebRTC
