sanzo77 Posted June 14, 2008 Posted June 14, 2008 Emh sorry, but i don't know how to istall a cab file, can you help me? Quote
Kelsenellenelvian Posted June 14, 2008 Posted June 14, 2008 One of 4 ways:Using nLite you add it as a hotfix in the hotifxes page. <-- Pre-installation.Using the RVM integrator you add it into the addons part. < Pre installation.Most of them (Remember I said MOST) can be extacted and you simply right click on the extracted inf and choose "Install", Or you run the incuded silent installer depending on the addon type. < Post-installation.Or WITH LOTS OF LUBRITCIATION!!! Get it? No? Darn... Quote
sanzo77 Posted June 14, 2008 Author Posted June 14, 2008 Ok, thank's. I'll use the post installation method (where available ). Quote
