Posted March 24Mar 24 The Media Player Classic project began in 2003 with the initial release, initially published as closed source, which was later converted and released as open source.Media Player Classic – Home Cinema, or MPC-HC for short, is an enhanced version with much more complete features than the basic version of Media Player Classic and is one of the best players available. Another version, MPC-BE (short for Media Player Classic – Black Edition), was released by Russian developers and is more modern in appearance and form. These programs feature small size, high stability, and full compatibility with the latest 64-bit versions of Windows. Media Player Classic Features and Benefits:Simple and easy-to-use user interfaceFull stability and very lightweightFull support for common audio and video formatsVery high-quality video playbackAbsence of the usual problems encountered with Korean players like KMPlayerFeatures a variety of image and audio settingsFull support for all types of subtitle formats and compatibility with Persian subtitlesMedia Player Classic Notes:When a new version of the K-Lite Codec Pack is released, the latest 32-bit version of MPC-HC is also included with the K-Lite package.To change the font, color, size, etc. for subtitles in the program environment, press the O key and switch to the default style from the Subtitles section of the opened window.Silent installation https://mir.cr/0KS1LLZX https://seyarabata.com/6803e895b88bd ا Edited 5 hours ago5 hr by T3rM1nat0Rr3
5 hours ago5 hr Author Changes in 2.4.2:Updates:Updated LAV Filters to version 0.79.2-28-gd35a3Updated MPC Video Renderer to version 0.9.7.2387Changes/improvements:Some tweaks to volume normalization algorithm.Adjusted clipping behavior for floating point audio when using volume boost. Should fix quality issues in some cases.Added warning prompt to boost that informs users about a better solution for the common issue of “voices are too quiet”, which is to enable mixing in the audio decoder (and adjust center mix level).Improved support of .cue files that contain links to multiple audio files.Fixes:Fixed a dragging issue with the exclusive mode seekbar.Several other small fixes and improvements.
