i need away just not clicked right click then install i want it just to click on it like an exe file and it run
is their a way and thx
If you know how to make a 7zip or WinRAR sfx use this command to install
rundll32 advpack.dll,LaunchINFSection NameOfINF.inf,,1
The ",,1" will make it silent
And make sure you put the .cab file in a folder named i386
doesn`t this requires to put the address of the file before it`s name
and thx
What method are you planning on using?
If 7zip SFX use
RunProgram="hidcon:cmd /c rundll32 advpack.dll,LaunchINFSection \"%%T\\NameOfINF.inf\",,1"
%%S - full path to the SFX archive file
%%T - full extraction path
If its winrar you dont have to do that, just use this (it will lanuch the DefaultInstall section if any)
Setup=NameOfINF.inf
TempMode
Silent=1
Overwrite=1
Setup=NameOfINF.inf
TempMode
Silent=1
Overwrite=1
Rick,
Using this method, do I still need to place my .cab file in the folder i386?
***Nevermind. I figured it out. The answer is YES.***
Aaron
Edited by ontheteam
