Jonnyboy Posted June 25, 2008 Posted June 25, 2008 (edited) I could use a littel help. I've been reading the tutorials here and using Mrs Peel's addons as a guide.But, I can't seem to delete the folders that get created.This doesn't seem to workHKLM,"%unin_runx%\%unin_name%","Cleanup1",0,"rundll32.exe advpack.dll,DelNodeRunDLL32 %16422%\%prog_dir%,8"HKLM,"%unin_runx%\%unin_name%","Cleanup2",0,"rundll32.exe advpack.dll,DelNodeRunDLL32 %16410%\%user_dir%,8"or,HKLM,"%unin_runx%\%unin_name%","Cleanup1",0,"rundll32.exe advpack.dll,DelNodeRunDLL32 "%16422%\%prog_dir%",8"HKLM,"%unin_runx%\%unin_name%","Cleanup2",0,"rundll32.exe advpack.dll,DelNodeRunDLL32 "%16410%\%user_dir%",8"or,HKLM,"%unin_runx%\%unin_name%","Cleanup1",0,"rundll32.exe advpack.dll,DelNodeRunDLL32 """%16422%\%prog_dir%""",8"HKLM,"%unin_runx%\%unin_name%","Cleanup2",0,"rundll32.exe advpack.dll,DelNodeRunDLL32 """%16410%\%user_dir%""",8"**EDIT** Alright, I have all of the folders, files and shortcuts, being deleted properly. Now, I just need to set the registry back the way it was before Firefox was installed and the installer should be complete. I found one of ricktendos and morphed mine to his. It WORKED!I have posted the inf and I am sure that there are several mistakes. If you could glance through and see where my errors are, I would appreciate it.; Jonnyboy's Firefox Addon[Version]Signature=$Windows NT$[Optional Components]Firefox[Firefox]OptionDesc ="%win_comp%"Tip ="%win_comp% v%disp_vers% %addo_made%"Modes =0,1,2,3CopyFiles =prog.10000,prog.10001,prog.10002,prog.10003,prog.10004,prog.10005,prog.10006,prog.10007,prog.10008,prog.10009,prog.10010,prog.10011,prog.10012,prog.10013,prog.10014,prog.10015,prog.10016,prog.10017AddReg =prog.addregProfileItems =prog.addshortcut,progql.addshortcut,progdt.addshortcut[DefaultInstall]CopyFiles =prog.10000,prog.10001,prog.10002,prog.10003,prog.10004,prog.10005,prog.10006,prog.10007,prog.10008,prog.10009,prog.10010,prog.10011,prog.10012,prog.10013,prog.10014,prog.10015,prog.10016,prog.10017AddReg =prog.addregProfileItems =prog.addshortcut,progql.addshortcut,progdt.addshortcut[DefaultUninstall]BeginPrompt =UninstallPromptEndPrompt =UninstallSuccessRunPreSetupCommands =KillProcess:1RunPostSetupCommands =WebReDirect,DelFoldersDelFiles =prog.10000,prog.10001,prog.10002,prog.10003,prog.10004,prog.10005,prog.10006,prog.10007,prog.10008,prog.10009,prog.10010,prog.10011,prog.10012,prog.10013,prog.10014,prog.10015,prog.10016,prog.10017,prog.infs,prof.linkDelDirs =prog.deldirsDelReg =prog.delregUpdateInis =prog.sysocCleanup =1ProfileItems =prog.deladdshortcut,progql.delshortcut,progdt.delshortcut[SourceDisksNames.x86]1 ="%win_comp% Files","%win_comp%.cab",,"i386"[DestinationDirs]prog.10000 =16422,"%prog_dir%"prog.10001 =16422,"%prog_dir%\chrome"prog.10002 =16422,"%prog_dir%\components"prog.10003 =16422,"%prog_dir%\defaults\autoconfig"prog.10004 =16422,"%prog_dir%\defaults\pref"prog.10005 =16422,"%prog.prof%"prog.10006 =16422,"%prog.prof%\chrome"prog.10007 =16422,"%prog_dir%\dictionaries"prog.10008 =16422,"%prog.exts%\{972ce4c6-7e08-4474-a285-3208198ce6fd}"prog.10009 =16422,"%prog_dir%\greprefs"prog.10010 =16422,"%prog_dir%\plugins"prog.10011 =16422,"%prog_dir%\res"prog.10012 =16422,"%prog_dir%\res\dtd"prog.10013 =16422,"%prog_dir%\res\entityTables"prog.10014 =16422,"%prog_dir%\res\fonts"prog.10015 =16422,"%prog_dir%\res\html"prog.10016 =16422,"%prog_dir%\searchplugins"prog.10017 =16422,"%prog_dir%\uninstall"prog.infs =17prof.link =16407,"%sub_dir%"[SourceDisksFiles]10000.fox=110001.fox=110002.fox=110003.fox=110004.fox=110005.fox=110006.fox=110007.fox=110008.fox=110009.fox=110010.fox=110011.fox=110012.fox=110013.fox=110014.fox=110015.fox=110016.fox=110017.fox=110018.fox=110019.fox=110020.fox=110021.fox=110022.fox=110023.fox=110024.fox=110025.fox=110026.fox=110027.fox=110028.fox=110029.fox=110030.fox=110031.fox=110032.fox=110033.fox=110034.fox=110035.fox=110036.fox=110037.fox=110038.fox=110039.fox=110040.fox=110041.fox=110042.fox=110043.fox=110044.fox=110045.fox=110046.fox=110047.fox=110048.fox=110049.fox=110050.fox=110051.fox=110052.fox=110053.fox=110054.fox=110055.fox=110056.fox=110057.fox=110058.fox=110059.fox=110060.fox=110061.fox=110062.fox=110063.fox=110064.fox=110065.fox=110066.fox=110067.fox=110068.fox=110069.fox=110070.fox=110071.fox=110072.fox=110073.fox=110074.fox=110075.fox=110076.fox=110077.fox=110078.fox=110079.fox=110080.fox=110081.fox=110082.fox=110083.fox=110084.fox=110085.fox=110086.fox=110087.fox=110088.fox=110089.fox=110090.fox=110091.fox=110092.fox=110093.fox=110094.fox=110095.fox=110096.fox=110097.fox=110098.fox=110099.fox=110100.fox=110101.fox=110102.fox=110103.fox=110104.fox=110105.fox=110106.fox=110107.fox=110108.fox=110109.fox=110110.fox=110111.fox=110112.fox=110113.fox=110114.fox=110115.fox=110116.fox=110117.fox=110118.fox=110119.fox=110120.fox=110121.fox=110122.fox=110123.fox=110124.fox=110125.fox=110126.fox=110127.fox=110128.fox=110129.fox=110130.fox=110131.fox=110132.fox=110133.fox=110134.fox=110135.fox=110136.fox=110137.fox=110138.fox=110139.fox=110140.fox=110141.fox=110142.fox=110143.fox=110144.fox=110145.fox=110146.fox=110147.fox=110148.fox=110149.fox=110150.fox=110151.fox=110152.fox=110153.fox=110154.fox=110155.fox=110156.fox=110157.fox=110158.fox=110159.fox=110160.fox=110161.fox=110162.fox=110163.fox=110164.fox=110165.fox=110166.fox=110167.fox=110168.fox=110169.fox=1[prog.10000]AccessibleMarshal.dll,10000.foxbrowserconfig.properties,10001.foxfirefox.exe,10002.foxfreebl3.chk,10003.foxfreebl3.dll,10004.foxjs3250.dll,10005.foxLICENSE,10006.foxnspr4.dll,10007.foxnss3.dll,10008.foxnssckbi.dll,10009.foxold-homepage-default.properties,10010.foxoverride.ini,10011.foxplc4.dll,10012.foxplds4.dll,10013.foxREADME.txt,10014.foxsmime3.dll,10015.foxsoftokn3.chk,10016.foxsoftokn3.dll,10017.foxssl3.dll,10018.foxupdater.exe,10019.foxupdater.ini,10020.foxxpcom.dll,10021.foxxpcom_compat.dll,10022.foxxpcom_core.dll,10023.foxxpicleanup.exe,10024.foxxpistub.dll,10025.fox[prog.10001]browser.jar,10026.foxbrowser.manifest,10027.foxclassic.jar,10028.foxclassic.manifest,10029.foxcomm.jar,10030.foxcomm.manifest,10031.foxen-US.jar,10032.foxen-US.manifest,10033.foxpippki.jar,10034.foxpippki.manifest,10035.foxreporter.jar,10036.foxreporter.manifest,10037.foxtoolkit.jar,10038.foxtoolkit.manifest,10039.fox[prog.10002]browser.xpt,10040.foxFeedConverter.js,10041.foxFeedProcessor.js,10042.foxFeedWriter.js,10043.foxjar50.dll,10044.foxjsconsole-clhandler.js,10045.foxjsd3250.dll,10046.foxmyspell.dll,10047.foxnsBookmarkTransactionManager.js,10048.foxnsBrowserContentHandler.js,10049.foxnsBrowserGlue.js,10050.foxnsCloseAllWindows.js,10051.foxnsDefaultCLH.js,10052.foxnsDictionary.js,10053.foxnsExtensionManager.js,10054.foxnsHelperAppDlg.js,10055.foxnsMicrosummaryService.js,10056.foxnsPostUpdateWin.js,10057.foxnsProxyAutoConfig.js,10058.foxnsSafebrowsingApplication.js,10059.foxnsSearchService.js,10060.foxnsSearchSuggestions.js,10061.foxnsSessionStartup.js,10062.foxnsSessionStore.js,10063.foxnsSetDefaultBrowser.js,10064.foxnsSidebar.js,10065.foxnsUpdateService.js,10066.foxnsUrlClassifierLib.js,10067.foxnsUrlClassifierListManager.js,10068.foxnsUrlClassifierTable.js,10069.foxnsURLFormatter.js,10070.foxnsXmlRpcClient.js,10071.foxspellchk.dll,10072.foxWebContentConverter.js,10073.foxxpinstal.dll,10074.fox[prog.10003]platform.js,10075.foxprefcalls.js,10076.fox[prog.10004]channel-prefs.js,10077.foxfirefox-branding.js,10078.foxfirefox-l10n.js,10079.foxfirefox.js,10080.foxreporter.js,10081.fox[prog.10005]bookmarks.html,10082.foxlocalstore.rdf,10083.foxmimeTypes.rdf,10084.foxprefs.js,10085.foxsearch.rdf,10086.fox[prog.10006]userChrome-example.css,10087.foxuserContent-example.css,10088.fox[prog.10007]en-US.aff,10089.foxen-US.dic,10090.fox[prog.10008]install.rdf,10091.fox[prog.10009]all.js,10092.foxsecurity-prefs.js,10093.foxxpinstall.js,10094.fox[prog.10010]npnul32.dll,10095.fox[prog.10011]arrow.gif,10096.foxarrowd.gif,10097.foxbroken-image.gif,10098.foxcharsetalias.properties,10099.foxcharsetData.properties,10100.foxcmessage.txt,10101.foxEditorOverride.css,10102.foxforms.css,10103.foxgrabber.gif,10104.foxhiddenWindow.html,10105.foxhtml.css,10106.foxlangGroups.properties,10107.foxlanguage.properties,10108.foxloading-image.gif,10109.foxmathml.css,10110.foxquirk.css,10111.foxsvg.css,10112.foxtable-add-column-after-active.gif,10113.foxtable-add-column-after-hover.gif,10114.foxtable-add-column-after.gif,10115.foxtable-add-column-before-active.gif,10116.foxtable-add-column-before-hover.gif,10117.foxtable-add-column-before.gif,10118.foxtable-add-row-after-active.gif,10119.foxtable-add-row-after-hover.gif,10120.foxtable-add-row-after.gif,10121.foxtable-add-row-before-active.gif,10122.foxtable-add-row-before-hover.gif,10123.foxtable-add-row-before.gif,10124.foxtable-remove-column-active.gif,10125.foxtable-remove-column-hover.gif,10126.foxtable-remove-column.gif,10127.foxtable-remove-row-active.gif,10128.foxtable-remove-row-hover.gif,10129.foxtable-remove-row.gif,10130.foxua.css,10131.foxviewsource.css,10132.foxwincharset.properties,10133.fox[prog.10012]mathml.dtd,10134.foxxhtml11.dtd,10135.fox[prog.10013]html40Latin1.properties,10136.foxhtml40Special.properties,10137.foxhtml40Symbols.properties,10138.foxhtmlEntityVersions.properties,10139.foxmathml20.properties,10140.foxtransliterate.properties,10141.fox[prog.10014]fontEncoding.properties,10142.foxfontNameMap.properties,10143.foxmathfont.properties,10144.foxmathfontCMEX10.properties,10145.foxmathfontCMSY10.properties,10146.foxmathfontMath1.properties,10147.foxmathfontMath2.properties,10148.foxmathfontMath4.properties,10149.foxmathfontMTExtra.properties,10150.foxmathfontPUA.properties,10151.foxmathfontSymbol.properties,10152.fox[prog.10015]gopher-audio.gif,10153.foxgopher-binary.gif,10154.foxgopher-find.gif,10155.foxgopher-image.gif,10156.foxgopher-menu.gif,10157.foxgopher-movie.gif,10158.foxgopher-sound.gif,10159.foxgopher-telnet.gif,10160.foxgopher-text.gif,10161.foxgopher-unknown.gif,10162.fox[prog.10016]amazondotcom.xml,10163.foxanswers.xml,10164.foxcreativecommons.xml,10165.foxeBay.xml,10166.foxgoogle.xml,10167.foxyahoo.xml,10168.fox[prog.10017]helper.exe,10169.fox[Prof.Link]%prog_dir%.lnk[Prog.Infs]%win_comp%.pnf,,,1[prog.addshortcut]Name =%prog_dir%,0x00000008,23CmdLine =16422,%prog_dir%,%win_comp%.exeSubDir =%sub_dir%WorkingDir =16422,%prog_dir%InfoTip =%prof_tip%[progql.addshortcut]Name =%prog_dir%,0x00000008,26CmdLine =16422,%prog_dir%,%win_comp%.exeSubDir =%ql_dir%WorkingDir =16422,%prog_dir%InfoTip =%prof_tip%[progdt.addshortcut]Name =%prog_dir%,0x00000008,25CmdLine =16422,%prog_dir%,%win_comp%.exeWorkingDir =16422,%prog_dir%InfoTip =%prof_tip%[prog.delshortcut]Name =%prog_dir%,0x00000002SubDir =%sub_dir%[progql.delshortcut]Name =%prog_dir%,0x0000000A,26SubDir =%ql_dir%[progdt.delshortcut]Name =%prog_dir%,0x0000000A,25[UninstallPrompt]Title =%unin_prom%Prompt =%unin_conf% %win_comp% v%disp_vers%?ButtonType =YESNO[UninstallSuccess]Prompt =%win_comp% %unin_done%[KillProcess]TASKKILL /F /IM %win_comp%.exeTSKILL %win_comp%[Prog.DelDirs]%16422%\%prog_dir%%16410%\%user_dir%%16407%\%sub_dir%[Prog.DelReg]HKLM,"%unin_arpc%\%win_comp%"HKLM,"%unin_path%\%win_comp%"[DelFolders]RUNDLL32 advpack.dll,DelNodeRunDLL32 %16422%\%prog_dir%,8RUNDLL32 advpack.dll,DelNodeRunDLL32 %16410%\%user_dir%,8[sysoc.Edit]%17%\sysoc.inf,Components,%win_comp%=*[WebReDirect]rundll32.exe url.dll,FileProtocolHandler %addo_info%rundll32.exe url.dll,FileProtocolHandler %addo_info%[prog.addreg]HKCR,".xht",,0x00000010HKCR,".xht",,0x00000000,"FirefoxHTML"HKCR,".xht","Content Type",0x00000000,"application/xhtml+xml"HKCR,".xhtml",,0x00000010HKCR,".xhtml",,0x00000000,"FirefoxHTML"HKCR,".xhtml","Content Type",0x00000000,"application/xhtml+xml"HKCR,"FirefoxHTML",,0x00000010HKCR,"FirefoxHTML",,0x00000000,"Firefox Document"HKCR,"FirefoxHTML","FriendlyTypeName",0x00000000,"Firefox Document"HKCR,"FirefoxHTML\DefaultIcon",,0x00000010HKCR,"FirefoxHTML\DefaultIcon",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE,1"HKCR,"FirefoxHTML\shell",,0x00000010HKCR,"FirefoxHTML\shell\open",,0x00000010HKCR,"FirefoxHTML\shell\open\command",,0x00000010HKCR,"FirefoxHTML\shell\open\command",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE -requestPending -osint -url ""%%1"""HKCR,"FirefoxHTML\shell\open\ddeexec",,0x00000010HKCR,"FirefoxHTML\shell\open\ddeexec",,0x00000000,"""%%1"",,0,0,,,,"HKCR,"FirefoxHTML\shell\open\ddeexec","NoActivateHandler",0x00000000HKCR,"FirefoxHTML\shell\open\ddeexec\Application",,0x00000010HKCR,"FirefoxHTML\shell\open\ddeexec\Application",,0x00000000,"Firefox"HKCR,"FirefoxHTML\shell\open\ddeexec\Topic",,0x00000010HKCR,"FirefoxHTML\shell\open\ddeexec\Topic",,0x00000000,"WWW_OpenURL"HKCR,"FirefoxURL",,0x00000010HKCR,"FirefoxURL",,0x00000000,"Firefox URL"HKCR,"FirefoxURL","FriendlyTypeName",0x00000000,"Firefox URL"HKCR,"FirefoxURL","URL Protocol",0x00000000HKCR,"FirefoxURL","EditFlags",0x00010001,02,00,00,00HKCR,"FirefoxURL\DefaultIcon",,0x00000010HKCR,"FirefoxURL\DefaultIcon",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE,1"HKCR,"FirefoxURL\shell",,0x00000010HKCR,"FirefoxURL\shell\open",,0x00000010HKCR,"FirefoxURL\shell\open\command",,0x00000010HKCR,"FirefoxURL\shell\open\command",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE -requestPending -osint -url ""%%1"""HKCR,"FirefoxURL\shell\open\ddeexec",,0x00000010HKCR,"FirefoxURL\shell\open\ddeexec",,0x00000000,"""%%1"",,0,0,,,,"HKCR,"FirefoxURL\shell\open\ddeexec","NoActivateHandler",0x00000000HKCR,"FirefoxURL\shell\open\ddeexec\Application",,0x00000010HKCR,"FirefoxURL\shell\open\ddeexec\Application",,0x00000000,"Firefox"HKCR,"FirefoxURL\shell\open\ddeexec\Topic",,0x00000010HKCR,"FirefoxURL\shell\open\ddeexec\Topic",,0x00000000,"WWW_OpenURL"HKCR,".htm",,0x00000000,"FirefoxHTML"HKCR,".html",,0x00000000,"FirefoxHTML"HKCR,".shtml",,0x00000000,"FirefoxHTML"HKCR,".shtml","Content Type",0x00000000,"text/html"HKCR,"ftp\DefaultIcon",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE,1"HKCR,"ftp\shell\open\command",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE -requestPending -osint -url ""%%1"""HKCR,"ftp\shell\open\ddeexec",,0x00000000,"""%%1"",,0,0,,,,"HKCR,"ftp\shell\open\ddeexec\Application",,0x00000000,"Firefox"HKCR,"gopher\DefaultIcon",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE,1"HKCR,"gopher\shell\open\command",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE -requestPending -osint -url ""%%1"""HKCR,"gopher\shell\open\ddeexec",,0x00000000,"""%%1"",,0,0,,,,"HKCR,"gopher\shell\open\ddeexec\Application",,0x00000000,"Firefox"HKCR,"HTTP\DefaultIcon",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE,1"HKCR,"HTTP\shell\open\command",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE -requestPending -osint -url ""%%1"""HKCR,"HTTP\shell\open\ddeexec",,0x00000000,"""%%1"",,0,0,,,,"HKCR,"HTTP\shell\open\ddeexec\Application",,0x00000000,"Firefox"HKCR,"https\DefaultIcon",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE,1"HKCR,"https\shell\open\command",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE -requestPending -osint -url ""%%1"""HKCR,"https\shell\open\ddeexec",,0x00000000,"""%%1"",,0,0,,,,"HKCR,"https\shell\open\ddeexec\Application",,0x00000000,"Firefox"HKLM,"SOFTWARE\Mozilla",,0x00000010HKLM,"SOFTWARE\Mozilla\Mozilla Firefox",,0x00000010HKLM,"SOFTWARE\Mozilla\Mozilla Firefox",,0x00000000,"1.8.1.14"HKLM,"SOFTWARE\Mozilla\Mozilla Firefox","CurrentVersion",0x00000000,"2.0.0.14 (en-US)"HKLM,"SOFTWARE\Mozilla\Mozilla Firefox\2.0.0.14 (en-US)",,0x00000010HKLM,"SOFTWARE\Mozilla\Mozilla Firefox\2.0.0.14 (en-US)",,0x00000000,"2.0.0.14 (en-US)"HKLM,"SOFTWARE\Mozilla\Mozilla Firefox\2.0.0.14 (en-US)\Main",,0x00000010HKLM,"SOFTWARE\Mozilla\Mozilla Firefox\2.0.0.14 (en-US)\Main","Install Directory",0x00000000,"C:\Program Files\Mozilla Firefox"HKLM,"SOFTWARE\Mozilla\Mozilla Firefox\2.0.0.14 (en-US)\Main","PathToExe",0x00000000,"C:\Program Files\Mozilla Firefox\firefox.exe"HKLM,"SOFTWARE\Mozilla\Mozilla Firefox\2.0.0.14 (en-US)\Main","Program Folder Path",0x00000000,"C:\Documents and Settings\All Users\Start Menu\Programs\"HKLM,"SOFTWARE\Mozilla\Mozilla Firefox\2.0.0.14 (en-US)\Main","Start Menu Folder",0x00000000,"Mozilla Firefox"HKLM,"SOFTWARE\Mozilla\Mozilla Firefox\2.0.0.14 (en-US)\Uninstall",,0x00000010HKLM,"SOFTWARE\Mozilla\Mozilla Firefox\2.0.0.14 (en-US)\Uninstall","Uninstall Log Folder",0x00000000,"C:\Program Files\Mozilla Firefox\uninstall"HKLM,"SOFTWARE\Mozilla\Mozilla Firefox\2.0.0.14 (en-US)\Uninstall","Description",0x00000000,"Mozilla Firefox (2.0.0.14)"HKLM,"SOFTWARE\Mozilla\Mozilla Firefox\2.0.0.14 (en-US)\Uninstall","Create Start Menu Shortcut",0x00010001,01,00,00,00HKLM,"SOFTWARE\Mozilla\Mozilla Firefox 2.0.0.14",,0x00000010HKLM,"SOFTWARE\Mozilla\Mozilla Firefox 2.0.0.14","GeckoVer",0x00000000,"1.8.1.14"HKLM,"SOFTWARE\Mozilla\Mozilla Firefox 2.0.0.14\bin",,0x00000010HKLM,"SOFTWARE\Mozilla\Mozilla Firefox 2.0.0.14\bin","PathToExe",0x00000000,"C:\Program Files\Mozilla Firefox\firefox.exe"HKLM,"SOFTWARE\Mozilla\Mozilla Firefox 2.0.0.14\extensions",,0x00000010HKLM,"SOFTWARE\Mozilla\Mozilla Firefox 2.0.0.14\extensions","Components",0x00000000,"C:\Program Files\Mozilla Firefox\components"HKLM,"SOFTWARE\Mozilla\Mozilla Firefox 2.0.0.14\extensions","Plugins",0x00000000,"C:\Program Files\Mozilla Firefox\plugins"HKLM,"SOFTWARE\mozilla.org",,0x00000010HKLM,"SOFTWARE\mozilla.org\Mozilla",,0x00000010HKLM,"SOFTWARE\mozilla.org\Mozilla","CurrentVersion",0x00000000,"1.8.1.14"HKLM,"SOFTWARE\RegisteredApplications",,0x00000010HKLM,"SOFTWARE\RegisteredApplications","Firefox",0x00000000,"Software\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities"HKLM,"SOFTWARE\Classes\.xht",,0x00000010HKLM,"SOFTWARE\Classes\.xht",,0x00000000,"FirefoxHTML"HKLM,"SOFTWARE\Classes\.xht","Content Type",0x00000000,"application/xhtml+xml"HKLM,"SOFTWARE\Classes\.xhtml",,0x00000010HKLM,"SOFTWARE\Classes\.xhtml",,0x00000000,"FirefoxHTML"HKLM,"SOFTWARE\Classes\.xhtml","Content Type",0x00000000,"application/xhtml+xml"HKLM,"SOFTWARE\Classes\FirefoxHTML",,0x00000010HKLM,"SOFTWARE\Classes\FirefoxHTML",,0x00000000,"Firefox Document"HKLM,"SOFTWARE\Classes\FirefoxHTML","FriendlyTypeName",0x00000000,"Firefox Document"HKLM,"SOFTWARE\Classes\FirefoxHTML\DefaultIcon",,0x00000010HKLM,"SOFTWARE\Classes\FirefoxHTML\DefaultIcon",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE,1"HKLM,"SOFTWARE\Classes\FirefoxHTML\shell",,0x00000010HKLM,"SOFTWARE\Classes\FirefoxHTML\shell\open",,0x00000010HKLM,"SOFTWARE\Classes\FirefoxHTML\shell\open\command",,0x00000010HKLM,"SOFTWARE\Classes\FirefoxHTML\shell\open\command",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE -requestPending -osint -url ""%%1"""HKLM,"SOFTWARE\Classes\FirefoxHTML\shell\open\ddeexec",,0x00000010HKLM,"SOFTWARE\Classes\FirefoxHTML\shell\open\ddeexec",,0x00000000,"""%%1"",,0,0,,,,"HKLM,"SOFTWARE\Classes\FirefoxHTML\shell\open\ddeexec","NoActivateHandler",0x00000000HKLM,"SOFTWARE\Classes\FirefoxHTML\shell\open\ddeexec\Application",,0x00000010HKLM,"SOFTWARE\Classes\FirefoxHTML\shell\open\ddeexec\Application",,0x00000000,"Firefox"HKLM,"SOFTWARE\Classes\FirefoxHTML\shell\open\ddeexec\Topic",,0x00000010HKLM,"SOFTWARE\Classes\FirefoxHTML\shell\open\ddeexec\Topic",,0x00000000,"WWW_OpenURL"HKLM,"SOFTWARE\Classes\FirefoxURL",,0x00000010HKLM,"SOFTWARE\Classes\FirefoxURL",,0x00000000,"Firefox URL"HKLM,"SOFTWARE\Classes\FirefoxURL","FriendlyTypeName",0x00000000,"Firefox URL"HKLM,"SOFTWARE\Classes\FirefoxURL","URL Protocol",0x00000000HKLM,"SOFTWARE\Classes\FirefoxURL","EditFlags",0x00010001,02,00,00,00HKLM,"SOFTWARE\Classes\FirefoxURL\DefaultIcon",,0x00000010HKLM,"SOFTWARE\Classes\FirefoxURL\DefaultIcon",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE,1"HKLM,"SOFTWARE\Classes\FirefoxURL\shell",,0x00000010HKLM,"SOFTWARE\Classes\FirefoxURL\shell\open",,0x00000010HKLM,"SOFTWARE\Classes\FirefoxURL\shell\open\command",,0x00000010HKLM,"SOFTWARE\Classes\FirefoxURL\shell\open\command",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE -requestPending -osint -url ""%%1"""HKLM,"SOFTWARE\Classes\FirefoxURL\shell\open\ddeexec",,0x00000010HKLM,"SOFTWARE\Classes\FirefoxURL\shell\open\ddeexec",,0x00000000,"""%%1"",,0,0,,,,"HKLM,"SOFTWARE\Classes\FirefoxURL\shell\open\ddeexec","NoActivateHandler",0x00000000HKLM,"SOFTWARE\Classes\FirefoxURL\shell\open\ddeexec\Application",,0x00000010HKLM,"SOFTWARE\Classes\FirefoxURL\shell\open\ddeexec\Application",,0x00000000,"Firefox"HKLM,"SOFTWARE\Classes\FirefoxURL\shell\open\ddeexec\Topic",,0x00000010HKLM,"SOFTWARE\Classes\FirefoxURL\shell\open\ddeexec\Topic",,0x00000000,"WWW_OpenURL"HKLM,"SOFTWARE\Classes\.htm",,0x00000000,"FirefoxHTML"HKLM,"SOFTWARE\Classes\.html",,0x00000000,"FirefoxHTML"HKLM,"SOFTWARE\Classes\.shtml",,0x00000000,"FirefoxHTML"HKLM,"SOFTWARE\Classes\.shtml","Content Type",0x00000000,"text/html"HKLM,"SOFTWARE\Classes\ftp\DefaultIcon",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE,1"HKLM,"SOFTWARE\Classes\ftp\shell\open\command",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE -requestPending -osint -url ""%%1"""HKLM,"SOFTWARE\Classes\ftp\shell\open\ddeexec",,0x00000000,"""%%1"",,0,0,,,,"HKLM,"SOFTWARE\Classes\ftp\shell\open\ddeexec\Application",,0x00000000,"Firefox"HKLM,"SOFTWARE\Classes\gopher\DefaultIcon",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE,1"HKLM,"SOFTWARE\Classes\gopher\shell\open\command",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE -requestPending -osint -url ""%%1"""HKLM,"SOFTWARE\Classes\gopher\shell\open\ddeexec",,0x00000000,"""%%1"",,0,0,,,,"HKLM,"SOFTWARE\Classes\gopher\shell\open\ddeexec\Application",,0x00000000,"Firefox"HKLM,"SOFTWARE\Classes\HTTP\DefaultIcon",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE,1"HKLM,"SOFTWARE\Classes\HTTP\shell\open\command",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE -requestPending -osint -url ""%%1"""HKLM,"SOFTWARE\Classes\HTTP\shell\open\ddeexec",,0x00000000,"""%%1"",,0,0,,,,"HKLM,"SOFTWARE\Classes\HTTP\shell\open\ddeexec\Application",,0x00000000,"Firefox"HKLM,"SOFTWARE\Classes\https\DefaultIcon",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE,1"HKLM,"SOFTWARE\Classes\https\shell\open\command",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE -requestPending -osint -url ""%%1"""HKLM,"SOFTWARE\Classes\https\shell\open\ddeexec",,0x00000000,"""%%1"",,0,0,,,,"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities","ApplicationDescription",0x00000000,"Firefox delivers safe, easy web browsing. A familiar user interface, enhanced security features including protection from online identity theft, and integrated search let you get the most out of the web."HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities","ApplicationIcon",0x00000000,"C:\Program Files\Mozilla Firefox\firefox.exe,0"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities","ApplicationName",0x00000000,"Firefox"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities\FileAssociations",,0x00000010HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities\FileAssociations",".htm",0x00000000,"FirefoxHTML"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities\FileAssociations",".html",0x00000000,"FirefoxHTML"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities\FileAssociations",".shtml",0x00000000,"FirefoxHTML"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities\FileAssociations",".xht",0x00000000,"FirefoxHTML"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities\FileAssociations",".xhtml",0x00000000,"FirefoxHTML"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities\StartMenu",,0x00000010HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities\StartMenu","StartMenuInternet",0x00000000,"FIREFOX.EXE"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities\URLAssociations",,0x00000010HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities\URLAssociations","ftp",0x00000000,"FirefoxURL"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities\URLAssociations","gopher",0x00000000,"FirefoxURL"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities\URLAssociations","http",0x00000000,"FirefoxURL"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities\URLAssociations","https",0x00000000,"FirefoxURL"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\DefaultIcon",,0x00000010HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\DefaultIcon",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE,0"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\InstallInfo",,0x00000010HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\InstallInfo","HideIconsCommand",0x00000000,"""C:\Program Files\Mozilla Firefox\uninstall\helper.exe"" /HideShortcuts"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\InstallInfo","ShowIconsCommand",0x00000000,"""C:\Program Files\Mozilla Firefox\uninstall\helper.exe"" /ShowShortcuts"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\InstallInfo","ReinstallCommand",0x00000000,"""C:\Program Files\Mozilla Firefox\uninstall\helper.exe"" /SetAsDefaultAppGlobal"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\InstallInfo","IconsVisible",0x00010001,01,00,00,00HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\shell",,0x00000010HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\shell\open",,0x00000010HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\shell\open\command",,0x00000010HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\shell\open\command",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\shell\properties",,0x00000010HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\shell\properties",,0x00000000,"Firefox &Options"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\shell\properties\command",,0x00000010HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\shell\properties\command",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE -preferences"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\shell\safemode",,0x00000010HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\shell\safemode",,0x00000000,"Firefox &Safe Mode"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\shell\safemode\command",,0x00000010HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\shell\safemode\command",,0x00000000,"C:\PROGRA~1\MOZILL~1\FIREFOX.EXE -safe-mode"HKLM,"SOFTWARE\Microsoft\MediaPlayer\ShimInclusionList\FIREFOX.EXE",,0x00000010HKLM,"SOFTWARE\Classes\https\shell\open\ddeexec\Application",,0x00000000,"Firefox"HKLM,"SOFTWARE\Clients\StartMenuInternet",,0x00000000,"FIREFOX.EXE"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE",,0x00000010HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE",,0x00000000,"Mozilla Firefox"HKLM,"SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\Capabilities",,0x00000010HKLM,"%unin_path%\%win_comp%","DisplayName",,"%win_comp% v%disp_vers% (Remove Only)"HKLM,"%unin_path%\%win_comp%","DisplayVersion",,"v%disp_vers%"HKLM,"%unin_path%\%win_comp%","Publisher",,"%addo_made%"HKLM,"%unin_path%\%win_comp%","HelpLink",,"%addo_help%"HKLM,"%unin_path%\%win_comp%","URLInfoAbout",,"%addo_info%"HKLM,"%unin_path%\%win_comp%","InstallLocation",0,"%16422%\%prog_dir%"HKLM,"%unin_path%\%win_comp%","UninstallString",,"rundll32.exe advpack.dll,LaunchINFSection %win_comp%.inf,DefaultUninstall"[STRINGS]win_comp ="Firefox"prog_dir ="Mozilla Firefox"user_dir ="Mozilla"sub_dir ="Internet"prof_tip ="Take back your internet!"ql_dir ="Microsoft\Internet Explorer\Quick Launch"prog.exts ="Mozilla Firefox\extensions"prog.prof ="Mozilla Firefox\defaults\profile"prog.prex ="Mozilla Firefox\defaults\profile\extensions"prog.user ="Application Data\Mozilla"disp_vers ="2.0.0.14"addo_made ="Addon by Jonnyboy"addo_help ="http://www.mozilla.com/"addo_info ="http://www.wincert.net/forum/index.php?showtopic=3637"unin_prom ="Jonnyboy's Addon Software Uninstaller"unin_conf ="Do you really want to remove"unin_done ="has been successfully removed from your computer"unin_path ="SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall"unin_runx ="SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnceEx"unin_arpc ="SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache"inst_run1 ="SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce"auto_pla1 ="SOFTWARE\Mozilla"auto_pla2 ="SOFTWARE\mozilla.org" Edited June 25, 2008 by Jonnyboy Quote
Gorki Posted June 25, 2008 Posted June 25, 2008 Why not remove all [prog.addreg] same way you add them? [DefaultUninstall] ...DelReg =prog.delreg...Same way you delete these afterward in your [DefaultUninstall] section [Prog.DelReg]HKLM,"%unin_arpc%\%win_comp%"HKLM,"%unin_path%\%win_comp%"You can also use Obsolete instead. Quote
Jonnyboy Posted June 25, 2008 Author Posted June 25, 2008 Why not remove all [prog.addreg] same way you add them? [DefaultUninstall] ...DelReg =prog.delreg...Same way you delete these afterward in your [DefaultUninstall] section [Prog.DelReg]HKLM,"%unin_arpc%\%win_comp%"HKLM,"%unin_path%\%win_comp%"You can also use Obsolete instead.I did not know that I could do that. I will give that a try.How does obsolete work?Thanks Quote
