Posted June 30, 200816 yr What changes would have to be made to an inf installer to make it compatible with both x86 and x64? The program is firefox, so not a 64-bit program.I guess the question should have benn, can a single inf be used in both an x86 and an x64 system? If so, how could the inf be written to accomplish it?tia
July 1, 200816 yr hmmm! good question, TBH I have never used a x64 operating system only 32 bit but I will do some investigating see if the DirID's (16422 etc etc) are compatible with x64 structureMaybe by looking at a x64 driver INF we could tell
July 28, 200816 yr Author With just a some initial testing I have been able to make an inf that installs in both Windows x86 and x64 systems. I need some script rewriting to get the registry settings correct. But, with some initial reading on MSDN, it appears easier than I could have imagined. It does doubles the size of the inf, though. Because you basically have two entries for everything.Tested only using DefaultInstall. Edited July 28, 200816 yr by Jonnyboy
July 28, 200816 yr '5eraph' over at RyanVM.net will be albe to help you with this more than anyone else i know. personally i never could get addons working 100% so i just converted all my program installs to silent installers and just run them after i install XP x64.
July 29, 200816 yr Author I finished writing the script the creates the inf for my addon maker. In testing it is compatible with XP, XPx64, Vista. I have only tested using defaultinstall. I need to make images and test in unattended.I still need to test Vista x64*EDIT*Premature, Vista failed "The Inf you selected does not support this method of installation.More work is needed. Thought I had it.*EDIT Again8Fixed. Vista works Edited July 29, 200816 yr by Jonnyboy
July 29, 200816 yr Author I've got it working and installing via unattended, but I get a pop-up about digital signature and Authenticode Technology when installing into WinXP (x64), still not tested Vista (x64). Anyone have any ideas on getting around that? Without going to Verisign or someone like that.The silent install installing via svcpack shouldn't generate this error code. But, that's for later testing.Again, thanks for the help.
December 18, 200816 yr Hello Jonnyboy, in the installation of any Addon I have the following mistake, you found some way of solving it.[ INF Install failure. Reason: Could not retrieve the system message. You may run out of the system resource." ]Thank you anyway.
January 22, 200916 yr Author Hello Jonnyboy, in the installation of any Addon I have the following mistake, you found some way of solving it.[ INF Install failure. Reason: Could not retrieve the system message. You may run out of the system resource." ]Thank you anyway.Sorry, I missed your post earlier.I am not sure what you need. Could you explain in a little more detail.Thanks
January 22, 200916 yr I am having one small problem when installing the Windows Sidebar v6.0.6001.18000 via right clicking on the inf file, I get this error message
January 22, 200916 yr @divisionadosYou need to install alky.there is a post on wincert telling you how to install sidebar on 64-bit XPi'll try to find it.... (if i get time)
January 23, 200916 yr I have installed alky, the instruction are the next, but not working for me: I have the same errorFULL INTRUCTIONS FOR WINDOWS XP 64-BIT (Admin, make this sticky please)Files needed and order to install1. Copy tskill.exe to System32 Folder.2. Install following:- Microsoft Visual C++ 2005 Redistributable Package (x86).exe |just install BOTH, i dont care y, but it works|- Microsoft Visual C++ 2005 Redistributable Package (x64).exe |just install BOTH, i dont care y, but it works|- Windows Internet Explorer 7 for Windows 64 bit Client-Server.exe- Windows Media Player 11 for Windows XP (64-bit).exe3. Install alky_1.1_trunk_032308-000051_2k3.msi and RESTART is a MUST.4. Right click on Sidebar.inf and press install and RESTART is a MUST (its annoying, but u have to do it AGAIN).5. Go to C:\Program Files (x86)\Windows Sidebar\Now read carefull:Locate files and DELETE them-sbdrop.dll.manifest-sidebar.exe.manifest-wlsrvc.dll.manifestif they are not there, SKIP this step.Now, press right mouse on following: sbdrop.dll (Patch Vista Library), wlsrvc.dll (Patch Vista Library) and sidebar.exe (Patch and Run Vista Executable)-Sidebar will appear (IVE done that on atleast 5 computers with XP x64 and worked every time), but sidebar will look dodgy. Dont panic, just close it on the taskbarLeft Bottom of your screen Press right on Sidebar icon and Close.6. Go to Control Panel Add-Remove Programs, find Windows Sidebar and press CHANGE, the menu will appear with following:The following will re-register Windows Sidebar, Repail Gadget Installer and also repair any Shared Gadgets you may have uninstalled.Keep pressing Ok, OK, OK...7. Go to C:\Program Files (x86)\Windows Sidebar\ Open sidebar.exe and i WILL WORK.I havent modified any files at all. All files are in their original state, download them from original sites:Windows Sidebar v6.0.6001.18000 at http://www.hr-host.com/wincert/ricktendo64...tl_AlkyXP1.1.7zalky_1.1_trunk_032308-000051_2k3.msi at http://www.fromvistatoxp.com/builds/1.1/al...-000051_2k3.rar
January 23, 200916 yr have you installed everything that it asks before you do right click and select install?1. Copy tskill.exe to System32 Folder. < have you done this?2. Install following:- Microsoft Visual C++ 2005 Redistributable Package (x86).exe |just install BOTH, i dont care y, but it works|- Microsoft Visual C++ 2005 Redistributable Package (x64).exe |just install BOTH, i dont care y, but it works|- Windows Internet Explorer 7 for Windows 64 bit Client-Server.exe- Windows Media Player 11 for Windows XP (64-bit).exe <<Have you done these??3. Install alky_1.1_trunk_032308-000051_2k3.msi and RESTART is a MUST. <<Done this? and have you restarted?4. Right click on Sidebar.inf and press install and RESTART is a MUST (its annoying, but u have to do it AGAIN).just pointing out what you might not have done before you go on to part 4...if this does not help then i'm sorry but i have not tried this yet so i won't know.... hopefuly you get this installed okay...
January 23, 200916 yr The problem is not the [Addon]Windows Sidebar v6.0.6001.18000, the problem is the file inf, for example with the [Addon]InterDownloadManger5.15 Build 4 (International) I have the same error.[ INF Install failure. Reason: Could not retrieve the system message. You may run out of the system resource. ]Post = [Addon]InterDownloadManger5.15 Build 4 (International)
January 23, 200916 yr Hmmm.... Well i'm sorry to say but i can't help anymore. I've done what I know mostly aboutIf i knew more about 64-bit INF i would of helped ya alot more. Maybe somebody else on WinCert might be able to help out?Sorry Mate
