Posted June 30, 200816 yr CooolSoft Power MP3 Cutter(MP3 Sound Cutter) 5.0This tool allow you to cut Mp3 , Wav Files and recored as wellI`m trying to find a new tool to make it an Addon each dayso I hope you Like it MD5:88A56F00D005C592D8EA770881D477ADSize:2.50 MBTrialweb Site: http://www.cooolsoft.com/Download to register It Extract the file Then go to PowerMP3Recorder.infin the String Section[strings];Add Your Registration In hereName=""Code=""Add your own Register Code I hope you Like it.any problem I will try to fix it and good bye Edited July 1, 200816 yr by Dark_Knight
July 1, 200816 yr Once before I was using Audio Editor, you might consider to try this one also:http://www.softpedia.com/get/Multimedia/Au...itor-Gold.shtmlCheers
July 1, 200816 yr Once before I was using Audio Editor, you might consider to try this one also:http://www.softpedia.com/get/Multimedia/Au...itor-Gold.shtmlCheerswell i installed it now it looks like a powerful tool thx
