is there a possible way to remove them permanently? its quite confusing specially you really have unknown devices you might overlook or think those drivers that your going install doesnt work anymore.
to remove them permanently U'll have to rightclick on devmgmt.msc, compmgmt.msc, choose Author.
in the applet, from the menu>View>uncheck "Show Hidden Devices", close the applet and say Yes to save changes.
btw these r not unknown, but NonPlugNPlay and what U call confusing is informative to others :)
U can use attached ones without hidden devices shown.
without.NonPlugNPlay.rar
  • Replies 1.3k
  • Views 360.4k
Thanks but still the same issue.
here is what I get
and I need that setup.exe tries to launch XPpro\\i386\\WINNT32.exe instead of i386\\WINNT32.exe
Please try to make it like the one in the pack with Autoplay folder which contains setup.cdd. You can also give me the source and I'll try to make it how I need it. Which way is easy for U.
Thanks for your time
Kaylar try this
Download
to amnesia I created this icon please see icon.7z
alternate autorun
Autorun
here is an alternate autorun program i found its very easy to edit the .ini file,
i have modded it for my needs and seems to work perfect on my multiboot dvd
give it a try
I try this and the blue version is amazing. :thumbsup_anim:
Good job.
But There is one mistake for me:THE END OF THE SETUP I GET UTIL.EXE ERROR.
PLEASE SOMEBODY HELP ME WHAT'S WRONG. :g:
Good job.
if the util.exe is the exact file,then xptsp dosent touch it and i dont think there even is a util.exe in windows.
_Update.01.11.09 (74 .res files + 2 .msc files in \Extra folder) :0)
5.78 MB md5: 55FA46760B9E8FB6C32E3915C3E7CC26
http://depositfiles.com/files/gf38w7mom
p.s. huge thanks to mona for researching the files that needed update
Sorry for not being able to figure things out, but the threads gotten as bit confusing. I used Dougie's version and it worked perfectly. I'd like to try the version - is there a changelog? Is Amnesia/the blue patch able to patch a Live system?
If someone doesn't mind bringing it up to speed in a few lines, I'd appreciate it, it's an awesome patch!!!
Just a FYI why I quoted the above, just one of the update posts I didn't understand :confused02:
Thanks guys/gals
like i said earlier, i was sick, and btw still am a bit.. this is ridiculous,this crappy virus or whatever i got is with me for 17 days and still going... any ways ive asked 2 members if they would like to take the reigns(fixit and amnesia as they have shown great interest and skill for editing the resources.)about the change logs , its my fault i kinda got lazy there sorry but life just got its way of throwing things a us that make it difficult to give time on the things we like/do/manage. again i am sorry about this.
Polish version XPtsp v.1.3 with last amnesia's update "_Update.01.11.09"
http://depositfiles.com/files/39aflnf27
md5: B33D465B4C5AE1D75DD6637E9429693E
rud if you could also post size, i would be happy to add ure distro to 1 st post when i can
Edited by bober
_Update.01.11.09.7z (74 .res files + 2 .msc files in \Extra folder)
meaning updated resources (new bitmaps, icons and some dialogs in .res files).
- U can add these files to the batch version of XPtsp (\Resources folder) with WinRar.
- or, to update a live system > extract XPtsp to a folder, add-overwrite updated .res files to the \Resources folder and .msc to the \Extra folder. add batches from VISO.Live.2.7 and start "1Copy.bat".
After patching, system will restart ...
Edited by amnesia
bober,
it's not really that big of a deal, don't think you should be apologizing for anything. We all have work/school/life/etc. Sorry you're sick, hope you get better soon bro :thumbsup_anim:
thanks amnesia for the explanation!
Didn't mean to ruffle anyone's feathers, just trying to make a clean install and find out which one I like best!
If someone would like to use sfx of 7z
Config.7z
;!@Install@!UTF-8!
Title="XP Theme Source Patcher v.1.3"
BeginPrompt="\tDo wykorzystania z Windows XP.\n\nXPTSP podmienia zasoby takie jak: ikony, bitmapy, \nAVI itp. z innych modifikator
i do know of the advantage of z7(best compression) but the biggest flaw of 7z is that the archive is not updatable thus why i kept on using rar sfx.(the .7z file i mean,hell id love to see an updatable 7z sfx but lets not wish for the moon or the sun)
EDIT: @dougiefresh, i believe there are 2 Lines that must be corrected. Found this out when making my XptspScritLive
WUAUCPL.MUI=%Sys%\WUAUCPL.CPL.MUI
WUCLTUI.MUI=%Sys%\WUCLTUI.DLL.MUI
Heres an XptspScript For Live Patching. Its just 50~70 Lines or so. this actually took 3 hours total with testing. i was way off from my estimate of 2-3 days.
Written in Autoit3.
*Note: This Script Just patch the Files in "Windows\" and "System32\", i just wanted the "main" files to be patched. Also, it does NOT keep the backup files
Instruction:
1. Extract Xptsp v1.X batch or Higher
2. Place XptspScriptLive.v1.0.exe in Directory containing XPtsp.bat
3. Run Script
Simple eZ and Fast. Enjoy
Download : http://www.mediafire.com/?maymoydtoyt
Edited by RisingXun
So, it is to necessary to add extra batch and some files to enable recompress entire XPtsp with itself :-)
With those extra files the pack should be smaller.
Please look at small addon to XPtsp. Extract to your "XPtsp.v1.3_batch" folder and run "compress 7zsfx.cmd".
The result is saved in ..\
Modify the addon as you wish.
http://www.mediafire.com/download.php?zlotnqwknun
Md5: CE96EE13433F1108CF85E99250550D9D
:confused02: I've been fiddling with the GUI's Live Patching code and it seems to patch everything correctly, but it doesn't want to uninstall correctly..... This is driving me crazy! :censored: :g: Ok, there has to be a way. Other programs do it, so can I. I'm going to try a different tack on this prob.... Wish me luck!
EDIT: When I say "uninstall correctly", perhaps it would be more accurate to say "uninstall completely". I see files that the XPtsp GUI patched, but now apparently won't replace with original files for some reason.....
RisingXun: I already got those lines in my INI file under the Live.Patch section ....
Edited by dougiefresh
