  • Replies 1.3k
  • Views 360.4k
I corrected sysdm.cpl.res. I added text-box after
"Customized By:"
"XP-tsp Version:"
and corrected localization of information about CPU, mem, etc.
May someone test it. I have not English XP.
http://depositfiles.com/files/1zp8w5pvw
MD5: cfa5f272e070cb8e54314f2abf64fc99
Edited by Rud
but i still dont get why this needs fixing..
good old unmodified original sysdm on a live system(with info generated courtesy of the oemgen from the addon version):
this one is when u click the support information button... :gleam:
Edited by bober
i cant spell anyways ..:)
and i need glasses...heha
for the damn sysdm info problems,thing is i have no clue why epople are still usign the manual batch version(use the gui)...if you are ,at least use the addon version(which is more complete)
anyways heres the oemgen patch for u cave people who are still using the manual batch:
OEM info generator (sysdm machine info AKA system control pannel)
use it and ure system ctrl pannel will be as beautiful as mine.. minus the nice specs...hehha
Edited by bober
I missed something, didn't I?
Where will I find oemgen?
Edit:
Thanks
You added it whilst I was witting :)
Edited by Rud
yeah, well peopel should realy use the addon version, im know its a ryan vm integrator only addon but its more betterness!
Edited by bober
What's Changed in v1.4.1.0: (Download link)
- Visual Theme installation is successful!
- Resources updated to match batch v1.4.1.
- SYSDM.CPL resource updated so that System Properties dialog looks correct.
- Fixed Page 3 Browse button so that Next button is enabled after selecting i386 folder.
Ok, it looks like the live patcher is about finished. So I need testers to make sure that everything appears correctly and functions normally.... Thanks!
Mr. FixIt: That trick you told me about for replacing the bootscreen works for the visual styles, too!
Edited by dougiefresh
I use the addon version almost exclusively! It's pure awesomeness! :thumbsup_anim:
there is blue ?
Yes there is, links are on the bottom in the first post ... :)
For those interested here's XPtsp Black v0.9 Beta 2: :unsure:
XPtsp black v0.9.beta2
MD5: 74B800C5954DEA077A5AE516E31BA015
Download:XPtsp black v0.9.beta2
220+folders.ico from green made black , all dialog back ground bmp's made black and had to cut out and re-mirror all objects. :sweatingbullets:
Also all 3 packs are updated: "Green, Blue and Purple"
gr.
Edited by Fixit
:worthy: This very nice.Good job.Well done and I will try it.
But I don't understand it what is Green pack?
Also all 3 packs are updated: "Green, Blue and Purple" (including NL versions)
When u look at the first post u wil see the green version...
At the moment there are 4 color scemes...
1:XPtsp 1.4.2 (original pack aka "Green") <first post
2:XPtsp Blue 0.9b7 <first post at the bottom
3:XPtsp Purple 0.9b7 <first post at the bottom
4:XPtsp Black 0.9b2 (new)
Edited by Fixit
Hmm...
i have a 5gb 4shared acount and i really like the download counter :rolleyes:
40 sec wait and download speeds are round 350 kb/s, thats faster than eg. rapid share witch gives me about 200 kb/s and up to 60 sec wait...
Maybe get something to drink and ur dl should be done in a minute or 2 ;)
its not that bad imo..
Edited by Fixit
true-true, i often do beer accelerated downloads :welcome:
p.s. ...one day, i'll do "Da Beer" theme or something...
Edited by amnesia
