I've just spoke with our hosting server administrator and he said:
This morning your server crashed due to a hardware issue, the hardware was replaced/apache reinstalled and your site restored. I believe this is the cause.
He also advises to users being prompted to download a file to clear their cache. Either that or delete your browser cache.
Hopefully, everything will be all right from now on.
I was able to get in through a notice and then saved a new bookmark. I have FF and it's set to clean everything when I close, so I don't know why it didn't work.
Thanks N1K
Yes, unfortunately we loose some of our posts, but luckily it wasn't a big damage ^_^
Hi, NIK...
Did you fix this problem?
Because ı updated my signature yesterday...
But when ı logged in forum, ı saw my old signature again..
when ı want to edit my post, edit settings becomes like that and there are some advertiesement links under our posts...
These are problems or what?
Thanks...
Edited by ALtF4
Problem is fixed now, as I said, unfortunately we lost some of the posts during the restore process :(
As for the ads, that's all right, I've put them yesterday so I can cover our server expenses.
Edit tab is working great on higher resolution, don't know which resolution are you using.
BTW, I'll remove those ads for our active members which includes you so you won't have problems in the future..
Thx
Thx
My resolution is 1280x1024...
Maybe it was about internet connection..
And thanks for information :)
Strange, it should work ok in that resolution..:(
But don't worry, I'll remove it for our staff members, sponsors and active members with more than 50 posts. Will try to do that today..
thx NIK...
Because really forum isnt appearing good :(
Pls look, so messy...
I'reading post,then these things then post :blink:
I hope ı could tell my opinions clearly...
Thx again...
