When you use an inf addon during an ui, the inf is automatically copied to %windir%\inf
if I you convert the inf to a silent exe and that during an ui, will the inf be copied to %windir%\inf
I'm not at home and it would take me a couple of hours to find out, using my laptop
tia
***EDIT***
When using the silent installer, the inf is not automatically copied to the %windir%\inf folder. Can the inf be copied by the inf?
I have been trying the copyINF directive, but that changes the name of the inf to OEM*.inf and can't be referenced by the uninstaller.
Anyone have any ideas?
Again, any help is appreciated.
thx
***EDIT***
Adding this to the config.txt for the silent installer seems to work.
RunProgram="hidcon:cmd /C copy /Y firefox.inf %windir%\inf"
Is there any downside to doing it this way?
Edited by Jonnyboy
