Geej Posted July 20, 2008 Posted July 20, 2008 Access Internet data safely by dropping unnecessary administrative privileges when accessing the Internet.DropMyRights by Michael HowardRead more at MSDN siteAnother article for observation on various mode of privilegeSilent Switchless Exe (SaferIESI.exe)Size: 305kbMD5:1C5B01931BE5C3284269016A5713AC3BInstalled Directory: Program files\Internet ExplorerKnown issue: Does not work with Google Toolbar. Need to disable it first. Otherwise IE will be unresponsive.Works for IE6 & IE7SaferIESI.exe contains 2 files1) Dropmyrights.exe & 2) SaferIE.exe Safer IE.exe is just an unUPXed autoit compiled script to launch IE in reduced privilege. You can change to your fav icon. Also, if dropmyrights.exe is not found in Program files\Internet Explorer folder, an error msg pop up, thereby alerting the user.Start Menu: Start -> All Programs -> Internet Explorer -> SaferIESaferIE.exe is set to run in Constrained mode (BTW, DropMyRights can run in 3 modes: Normal , Constrained, Untrusted) Quote
