Posted July 20, 200816 yr Access Internet data safely by dropping unnecessary administrative privileges when accessing the Internet.DropMyRights by Michael HowardRead more at MSDN siteAnother article for observation on various mode of privilegeSilent Switchless Exe (SaferFireFoxSI.exe)Size: 316kbMD5: CECE3073E7EF7F117C98F78776E65713Installed Directory: Program files\Mozilla FirefoxSaferFireFoxSI.exe contains 2 files:1) DropMyRights.exe 2) SaferFirefox.exe <-- -- -- Launcher using Autoit compiled script. File not UPXed. So can change your fav icon if you want. A simple msg will popup if the 2 files are not found at its intended location. SaferFirefox.exe is set to run in Constrained mode Shortcut is Start->All Programs ->Mozilla Firefox -> Safer FirefoxIt is intended to add to your existing Firefox svcpack. 1)Pls unpack your existing Firefox addon program2)Put the downloaded SaferFireFoxSI.exe into the svcpack folder (SaferFireFoxSI.exe is also Silent switchless type)3) Edit your entries_Firefox_or_something.ini with[AddProgram]Firefox-2015.exe <-- This is my existing entry. You may have different names.SaferFireFoxSI.exe <--- Add New entry (Must be after Firefox-2015.exe line, not before)4) Repack back the whole package into original formOther: If you have Firefox already installed, just run SaferFireFoxSI.exe to install.Additional info:Q. How do you know that Firefox is running in reduced privilege?A: Well, Start SaferFirefox thru the start Menu. Try saving this webpage in C:\ or C:\Program Files or C:\Windows or C:\Windows\System32 If you get a warning message, asking you to save to My Documents instead, then Firefox is running in reduced privilege. (which also means spyware can't infect your critical system directory) Note: It will also block registry writing to HKLM if any (but not HKCU). However, if you are installing Firefox extensions, then don't run in Reduced privilege.(Note: DropMyRights does not works on Vista) Edited August 30, 200816 yr by Geej
July 20, 200816 yr Thanks.This is only necessary if you are logged into your machine as an administrator, right?
July 20, 200816 yr Author Yes, this is only necessary if you are logged into your machine as an administrator (which generally what majority of home user do)
August 30, 200816 yr Author Updated program icon (i.e. saferfirefox.exe) and add some some additional info at the end of 1st post.
