thealexweb Posted July 24, 2008 Posted July 24, 2008 I have a Dell Optliplex GX 260 that has two hard drives one 40GB and one 80GB. I was reinstalling XP and I accidentally deleted the partition on the 80GB, I installed XP on the primary 40GB but now Windows can't see the 80GB. Well I say it can't see it, I can't use it but it appears in the Device Manager. I thing I must have uninstalled it or something. The hard drive that no longer works properly is a Maxtor 6L080J4.Please help, this is my primary computer and I need to get it working as soon as possible.Thanks in advance.The computer is now running Windows XP Service Pack 3. Quote
eryen Posted July 24, 2008 Posted July 24, 2008 If u need all documents/pics/progs on second drive u have to unformat or recover second (80GB) drive.U may use r-studio or etc. to recover.If u dont need any files at second drive.Right click to My Computer. Select Manage.U will see Disc Managment on left side in new opened windows. Select it.In right side of windows u will see all disc/cd/dvd-rw connected to your computer.Probbaly Disc 1 is your second disc. (80GB) Right click on it and select create new partition. Then just press next>next>next You will see your disc on My Computer as D: or E: Quote
thealexweb Posted July 24, 2008 Author Posted July 24, 2008 If u need all documents/pics/progs on second drive u have to unformat or recover second (80GB) drive.U may use r-studio or etc. to recover.If u dont need any files at second drive.Right click to My Computer. Select Manage.U will see Disc Managment on left side in new opened windows. Select it.In right side of windows u will see all disc/cd/dvd-rw connected to your computer.Probbaly Disc 1 is your second disc. (80GB) Right click on it and select create new partition. Then just press next>next>next You will see your disc on My Computer as D: or E:It worked, thank you so much! Quote
