Posted August 7, 200816 yr JkDefrag GUI AddOn v0.1.1 Info: Add shortcut for JkDefrag GUI to Control Panel. Add a menu entry to right click on Hard Disk to Defragment. It replaces default defragmenter, but DOES NOT ovrewrite it, it just uses a reg tweak for this. Default defragmenter is still accessible through start menu. Default screensaver is set to JkDefrag screensaver. This one, after it ends defragmentation, will launch default Windows sccreensaver : logo.scr. UninstallableSupported Languages: English, French. (Feel free to ask a language support if JkDefrag GUI support this language).ChangeLog:0.1.1:- Fixed a little issue when uninstalliog : entre in sysoc.inf wasn't removed0.1.0:- Initial releaseMD5: 437DEC13C6F77E5D94D6BC1DBC1317CDSize: 5.08MBWebsite: http://www.emro.nl/freeware/ Edited August 7, 200816 yr by Kal
August 7, 200816 yr Kal nice work, how ever I don't wont to be rude,but you should not spend your free time to do this since I already made similar addon way back with all languages included,they are almost the same... Here is the link...Never the less I like your work mate
August 7, 200816 yr Author Arg, next time I should try Search function By the way, your AddOn doesn't include French translation for Uninstall entry in Add/Remove manager, and it sets english as default language for JkDefrag GUI. So, even if I've found yours before, I should make this one to make it intertionalized Cheers!
August 7, 200816 yr So you did use search after all! Yes I had to make up an excuse (read above almost) to keep you rolling since you already spend time for making it!
August 8, 200816 yr nice work !New features are awesome!if you put it into windows disk management that i would love it
August 8, 200816 yr Author Will, I guess it's not possible to replace default defragmenter in Windows Disk Management...
