Posted August 11, 200816 yr I have created silent installs for a couple of programs, but I having some problems.The programs install silently to just before the end when they open up a read me file & you need to close in order for the install to finish which is frustrating, but Is there a program that can run in the background and kill notepad automatically when it is launched just while WPI is working.Thanx
August 11, 200816 yr I am not very good at Sil.Ins. but you may need to use a dif. switch. Post the program name, I am sure Rick or someone will need that info.
August 11, 200816 yr Author I am not very good at Sil.Ins. but you may need to use a dif. switch. Post the program name, I am sure Rick or someone will need that info.Thanx LUZR4LIFE, I forgot to leave it.The Program is CachemanXP
August 12, 200816 yr I'm using autoit to install. Tested on XP host with standard notepad as default text editor. Works ok. Please see how it goes into actual install.If you have other text editor slipstreamed, just ensure it slipstream later than this addon. (An numbered index addon always helps, such as 001cachemanXP_Addon.cab will install earlier than 003Notepad++_addon.cab)Limited hosting period (30 days if no download)MD5: AA229C78C2CBA80D3FADB007FA75DBECIf somehow script hangs at T13 during installation, the hotkey to exit the script is CTRL+ALT+x
August 12, 200816 yr Author I'm using autoit to install. Tested on XP host with standard notepad as default text editor. Works ok. Please see how it goes into actual install.If you have other text editor slipstreamed, just ensure it slipstream later than this addon. (An numbered index addon always helps, such as 001cachemanXP_Addon.cab will install earlier than 003Notepad++_addon.cab)Limited hosting period (30 days if no download)MD5: AA229C78C2CBA80D3FADB007FA75DBECIf somehow script hangs at T13 during installation, the hotkey to exit the script is CTRL+ALT+xHi Geej, Thanx for your help and time, and the script works great. I did try using autoit but couldnt get it to work. I have just 1 little problem I want it for the WPI I am creating not as a addon, and will have notepad2 as my default text editor. If its not to much to ask, could you show or send me the code you used for the autoscript so that I can look it over, & would it be easy enough to change notepad to notepad2?Thanx...
August 12, 200816 yr Did you try using the built in tskill option from wpi to kill notepad???i.e:tskill notepad <-- Place that in commandline # 2? ?
August 12, 200816 yr Audigy,Just tested actual install at T13, doesn't work. But it can close the notepad readme. (I will not do any T/s or fine tuning the script since you are already using autoit)For the benefit of any user reading this post, kindly do not download and add into your built.Code I'm using isHotKeySet("^!x", "MyExit");the script to exit when CTRL+ALT+x is pressedTooltip ( "Installing CachemanXP", 200, 420 )Run ("setup.exe /S")WinWait ("Readme.txt - Notepad","README for Outertech")WinClose ("Readme.txt - Notepad","README for Outertech");WinWait ("CachemanXP - unregistered","Toolbar") <-- during XP setup testing, this screen does not show up. But it show up during normal installation.;WinClose ("CachemanXP - unregistered","Toolbar") <-- during XP setup testing, this screen does not show up. But it show up during normal installation.ProcessWaitClose ( "setup.exe" )Func MyExit() Exit EndFuncYou should consider Kelsenellenelvian's suggested method. If it works, it is much easier than Autoit.Good luck
August 12, 200816 yr Author Did you try using the built in tskill option from wpi to kill notepad???i.e:tskill notepad <-- Place that in commandline # 2Great Idea Kelsenellenelvian, I was to busy concentrating on getting it to work from a batch file, I didnt even think about the tskill option in WPI.It just goes to show you Sometimes, the best answer is the simplest answer. Thanx Kel it worked a treat. Audigy,Just tested actual install at T13, doesn't work. But it can close the notepad readme. (I will not do any T/s or fine tuning the script since you are already using autoit)For the benefit of any user reading this post, kindly do not download and add into your built.Code I'm using isHotKeySet("^!x", "MyExit");the script to exit when CTRL+ALT+x is pressedTooltip ( "Installing CachemanXP", 200, 420 )Run ("setup.exe /S")WinWait ("Readme.txt - Notepad","README for Outertech")WinClose ("Readme.txt - Notepad","README for Outertech");WinWait ("CachemanXP - unregistered","Toolbar") <-- during XP setup testing, this screen does not show up. But it show up during normal installation.;WinClose ("CachemanXP - unregistered","Toolbar") <-- during XP setup testing, this screen does not show up. But it show up during normal installation.ProcessWaitClose ( "setup.exe" )Func MyExit() Exit EndFuncYou should consider Kelsenellenelvian's suggested method. If it works, it is much easier than Autoit.Good luckThanx for you all help Geej and sorry for all the extra work I put you through The code you wrote will come in handy in future projects
