Well,
we really don't have luck.. :(
We've change our hosting provider to get away from the hacker that has targeted us for some unknown reason. Now, when we've settled with our new host, a new problem. After I've discovered that I can't access I tried to ping it by an IP address and I was able to ping it successfully. So that was obviously a DNS problem.
I've reported this issue to our host and I got fast reply after several minutes..
Hi,
I have checked and found that the DNS zone file was missing that has been setup now. Please allow sometime for DNS propagation and your site will start loading fine.
- But, how on earth did that file got removed/deleted???
So, if you see the forum now, that means DNS propagation has finished on your side. As usual, I do apologize for this problem, but at least we didn't loose anything from the forums :)
Regards,
Nik
3 times in one week :S
Well Rick, how would you called this except bad luck. Not one of these three times was my fault. What can I do? :(
Here is what our host said regarding this issue:
Well this can happen due to cPanel malfunction and hope it won't be repeated in future.
-I'm certainly hope that it won't happen it the future too..
