should i move to 64 bit and is my pc capable to have 64bit?
Guest snakecracker
Posted (edited)
hello
i was looking at my pc spec. and came across 64 architecture
on intel
Edited by snakecracker
Throw in an empty HDD and give it a whirl! :)
If it doesn't work, you haven't lost anything.
Although I would avoid XP-64 like the plague though. Driver issues mainly.
Vista-64 is pretty solid. I've been using it for months.
Guest snakecracker
ok thanks Mr_Smartepants
ill give it a try.
Guest snakecracker
ok i tried to boot from the disc but it don't seem to boot.
it goes into some ms dos stuff then ask's for something
i think its to do with my BIOS
but how can i tell if my BIOS is capable with 64 bit???
thanks in advace
Guest snakecracker
ok thanks im not gonna try to go x64 bit as my pc has some error's
i have Bad RAM :crying_anim02:
thanks for your help! :D
locked topic because i can't go on 64-bit on my computer due to the MoBo can not handle it. ~Snake
