[Addon]Beyond Compare 3.1.7.10856 11/07/2009
bjfrog
Powerfull utility for comparing your files and folders
Beyond Compare allows you to quickly and easily compare your files and folders. By using simple, powerful commands you can focus on the differences you're interested in and ignore those you're not. You can then merge the changes, synchronize your files, and generate reports for your records.
you can visit Scooter software website for more details.
Beyond Compare3 is not freeware,it has 30 days free trial.
Size: 5.14 MB (5,395,861 bytes)
MD5: a4bf260d316c7509eac3da29905fc8ef
Here is the Additional Formats file for Beyond Compare 3 include all file formats (for windows) from
HERE
just double click and select file formats that you want support ,It will import into your Beyond Compare 3
MD5 A6D6CE0E480599F9EA0487DDB36C091A
Size 2.76 MB
Change Log
Nov 7 2009 update to v3.1.7.10856
Feb 11 2009 update to v3.0.15.9758
Jau 25 2009 update to 3.0.14.9740
Dec 06 2008 Update to v3.0.11.9510
Oct 21 2008 update to version3.09.9222
Oct 13 2008 update to version3.07.9037 correct an error of file formats backup
Sep 05 2008 version3.03.8855 with all windows files formats backup
Edited by bjfrog
Link to comment
Share on other sites
  • 8 months later...
