shahed Posted September 16, 2008 Posted September 16, 2008 HiAm trying to add ONLY a context menu. For example i want to have this as the name "tools" egTools>addon maker, script editor, and so onBasically all my tools and utilities are located in system32/tools directory, and i want to access them via context menu (right click>tools) and also have 2 or 3 menu's inside the "tools" context menu, and have them pointed to my exe files which are located in system32/tools directory.How do i add this context menu(s) via inf?A basic inf template for this will do, as i do have a bit experience with inf files.Thank you Quote
ricktendo Posted September 16, 2008 Posted September 16, 2008 I think in addition to the context menu you need a program...Look at my cmenu addon or kels uber pack, they both have a context menu editor Quote
shahed Posted September 16, 2008 Author Posted September 16, 2008 I think in addition to the context menu you need a program...Look at my cmenu addon or kels uber pack, they both have a context menu editorThanks rick, i will have a quick look at your cmenu and kels uberpack addons inf file Quote
ricktendo Posted September 16, 2008 Posted September 16, 2008 Install CMenu and then use the CMExtEd.exe to add any new context menu entries/programs/groups you may want...then export the changes you made from the registry, convert them to inf and add them to my cmenu inf file Quote
shahed Posted September 16, 2008 Author Posted September 16, 2008 (edited) Install CMenu and then use the CMExtEd.exe to add any new context menu entries/programs/groups you may want...then export the changes you made from the registry, convert them to inf and add them to my cmenu inf fileThanks for your help rick, i will do that and will let you know.Btw am trying to add these context menu for vista x86 OS not XPThank youEDIT:It worked. Thanks so much ricks :thumbsup_anim: Edited September 17, 2008 by shahed Quote
