JurgenDoe Posted September 16, 2008 Share Posted September 16, 2008 I promised Nick to write this tutorial but it took me a bit longer do to much work I have :angry: Ok here we go:1. Open a new image File - New with transparent background.Fill this layer with the your choise of your color, but not to dark.Now select the Type Tool and use the same color that you used on your backround.Type the wanted text and click ok. Ctrl + leftclick your text layer to select the text. Your image should now look like this2. Now go to Layer - Rasterize - Type Use Brightness/Contrast to darken the text a little bit.Image - Adjust - Brighntess/Contrast.Brightness: -10Contrast: 0Now we add some inner shadow to the text to give the text that chiseled look.Go to Layer - Layer Style - Inner Shadow. Use the following setting:Mode: MultiplyOpacity: 75 %Angle: 120Distance: 7Choke: 7Size: 7 If you use the effect on a bigger text you may want to increase the distance a little bit.Your image should now look like this.3. With the text still selected create a new Layer and name it white shadow.Turn off the text layer by clicking on the eye icon Select White as your foreground color and fill your selection.Edit - Fill - Forground color Deselect with (Ctrl + D).Still at the White Shadow layer go to Filter - Blur - Gaussian Blur - Radius: 2 pixels.Your image should now look like this4. Select the Move Tool and move the white shadow layer 2 pixels down and 2 pixels to the right using the arrow keys on your keyboard.Turn on the text/cutout layer again.Turn down the opacity on the white shadow layer till you get your wanted effect.I turned the opacity down to 40 %.Your image should now look like this5. To get rid off that "plastic" look we'll add some nifty cool effects Go to layer 1 (background layer).Duplicate this layer by dragging it down to the Create New Layer icon.You now should have a layer 1 copy.Turn off the new layer and go back to layer 1.Now go to Filter - Noise - Add Noise - Amount 25, Uniform and Monochromatic checked.Select the text/cutout layer and apply the same effect.Now go to the Layer 1 Copy layer and turn down the opacity to 90 %.Do the same with the text copy layerYour final image should look like thisI hope you like this little tutorial and have fun by doing it on your own Quote Link to comment Share on other sites More sharing options...
Guest ALtF4 Posted September 17, 2008 Share Posted September 17, 2008 Who said photoshop? :gleam: If ı say that ı was waiting for this subject, ı hope you believe.I am interested in photoshop and ı will learn many things from you if you continue this topic...Thnak you... Quote Link to comment Share on other sites More sharing options...
JurgenDoe Posted September 17, 2008 Author Share Posted September 17, 2008 Well I believe you because I had many other ppl who was waiting for that too Quote Link to comment Share on other sites More sharing options...
NIM Posted September 17, 2008 Share Posted September 17, 2008 Well I believe you because I had many other ppl who was waiting for that too Thx mate, now this looks like a simple thing (if you have a tutorial, that is) Quote Link to comment Share on other sites More sharing options...
JurgenDoe Posted September 19, 2008 Author Share Posted September 19, 2008 It is very simple Nick ... everybody can do it Quote Link to comment Share on other sites More sharing options...
