Windows Live Messenger 9
now you will find in the add/remove the Windows live messenger 9
A photo of it
Download
MD5:3efca5d80942238d80a9c26471c17969
Sign In Assistant Is Included In the Pack and well as Windows Live Upload
Messenger Plus ! Live
Web Site : http://msgplus.net/
Download
Version:4.80.0.356
MD5: 00fb1af3f8fee6abe2211bfdf2b22064
Attention:
Integrate After WLMessenger
Change Log
15-2-2009
Updated WLM To 14.8064.206
Updated MSN PLUS to 4.80
16-1-2009
Updated Msg Plus ! Live To 479.0.353
19-12-2008
Added MSG Plus !Live Addon
17-12-2008
Updated To Build 14.0.8050.1202
Uninstaller Now works 100%
Windows Live Call Uninstall Is Fixed
Used Shark007 tutorial To Minimize Size
Removed Windows Live Mail until i remake the Installer
2-10-2008
Made it totally silent
Merged Sign In assistant with the addon
Fix uninstall problem
Edited by DaRk MaDnEsS
Updated added More tools and Fixed the Uninstallable Problem
i hated the look of v8.5
v9 looks a little better
V9 is totally Different than the old one
Updated With Windows Live Mail
and thx for your replay
Updated with a Fixed Version
Updated
hey would you happen to know if i remove outlook express(with nlite for example), if that would interfere with windows live mail? is it a separate program from outlook? or something that is hooked into it?
and yeah i do like the looks of v9 much more than 8.5 :D well except i dont like those horrid green boxes around the user pictures :P
well the last time i did that no problem happened but i can't confirm it would work 100%
so basically Windows Live mail doesn't need Outlook but i`m not really sure so can't say Yes or no for sure
hi DaRk MaDnEsS
did you not add that plus feature yet i sent you ?
i Will Upload The WLMail + MSG Plus Now and Added Them
But for the True Addon
i hope it release soon before i close my Pc for exams
Added Messenger Plus ! Live Svcpack Addon
I will make another Topic For Other Live Essential
Thanks @DaRk MaDnEsS. Excellent work :prop: :punk: :thumbsup_anim:
BTW: How do I added my own patched files to ur silent pack?
You'll have to extract DaRk MaDnEsS WLMessenger9.exe first and then manually copy patched files in that root navigating to PFiles\Windows Live\Messenger
After that you'll have to make new WLMessenger9.exe again so you could make SVCPACK Addon again.
Updated Messenger Plus to 4.7.0.353 !
Updated Windows Live Messenger
Sorry For late upload
i already made the addon yesterday but the net was down
i didn't notice that i didn't updated the MSG Plus
i will Upload the new one soon
Edit:Updated MSG PLUS to 4.80.356
  • 3 months later...
