Posted November 16, 200618 yr from here http://www.tweakvista.com/Windows Vista: Customize the User Interface tweaks Disable pop-up balloon tips Enable New Boot screen in Vista Beta 2 Enable New Vista Aero Cursors Enable Vista Glass look on Unsupported Video Cards Fix Windows Vista Fonts Force Vista Glass on Compatible Hardware Kill Security Center Notifications Show Run Command on Start Menu Slow Motion Aero Animations on Demand Tweak your glass window borders Windows Vista: Usability Tips Checkbox Select Alternative Install Vista without product key Launch Flip 3D Alt+Tab Replacement Make NAS (Network Attached Storage) devices work in Vista Missing the old File, Edit, View menu bar? Run as administrator start menu keyboard trick Stop autostart applications Wireless Network Search Refresh Windows Vista: Performance Tweaks Disable Network Printer Search Disable Welcome Center Speed up Start Menu Search Vista Beta 1 Service Guide: Part 1 Vista Beta 1 Service Guide: Part 2 Windows Vista: Software Tweaks Add search providers to Internet Explorer 7 Create a Shortcut for Flip 3D Enable Add-ins in Windows Live Messenger Enable Vista Glass on Intel GMA 950 Graphics Cards Internet Explorer 7 keyboard shortcuts Internet Explorer 7 Privacy Tip Internet Explorer 7 Quick reference Sheet Internet Explorer 7 User Agent tweaking tool Remove Windows Mail splash screen Resize Partitions with Vista Disk Management Windows Vista: Security Tweaks Start Menu Privacy Tweaks Tweak User Account ProtectionWindows Vista: Links Learn How To Add Glass to your Applications Official Windows Vista website Vista Blogs Windows Vista Development Site Windows Vista Logos Windows Vista UX Guidelines from here http://www.tweakvista.com/ check for updates
