1) If I don't want to anybody modify or Extract or read any comment in my winrar sfx file (can execute only) How I do (I tried to check Lock achive Box It still)
2) I used SciTE Scriptwriter for write autoit script and I used winrat sfx to complete it(after extract run command)
but If I don't want to show any automation when it process How I do? ( I tried after extract command app.exe /S don't work)
Sorry for poor English
#1 Cannot be done (the only way to make your archive like that is to password protect it) But that defeats the purpose of making a silent install as you would have to enter a password in when it is ran.
#2 Cannot be done for sure...
For me it's not clear what you want to do. If you want to make a real addon (install with *.inf) on this way, then I don't know the solution and I can't understand what for you need it.
But you can make your own installer (ie autoit, scrambled) and install it during T-13 as SilentInstaller Addon or with RunOnceEx. People would need to decompile your *.exe if they would like to see the technics you used.
