Posted September 27, 200816 yr Ok.....I'm creating a shortcut for a game in the "Games" folderof the start menu....No big deal... I've done this several times for other games......Well this particular one doesn't want to cooperate......Here is the code for creating the shortcut... [Maryo_AddShortcut]Name =%PROG_NAME%CmdLine=16422,%PROG_NAME%,%SMaryo1%SubDir=GamesWorkingDir=16422,%PROG_NAME%InfoTip=Secret Maryo Chronicles[Strings]PROG_NAME="Secret Maryo Chronicles"SMaryo1="Secret Maryo Chronicles.exe"And here is what it does.... The info tip, the name, and everything works.....But for some reason the "target" isn't correct.....What the hell..... I would appreciate some help with this... BEFORE I throw the puter out in the yard!!! Edited September 27, 200816 yr by *Reaper*
September 27, 200816 yr [Maryo_AddShortcut]Name =Secret Maryo ChroniclesCmdLine=16422,%PROG_NAME%,%SMaryo1%SubDir=GamesWorkingDir=16422,%PROG_NAME%InfoTip="Secret Maryo Chronicles"[Strings]PROG_NAME="SECRET~1"SMaryo1="SECRET~1.EXE" Edited September 27, 200816 yr by Rocco
September 27, 200816 yr Correct...for executable's with spaces use 8.3 filenamesIf you have CMenu or SendToA3X you can get this (I think there is also an option in kels uberpack clipname)BTW you don't have to use it for the CmdLine's SubDir only the executable
