Posted September 28, 200816 yr FlashGet Quote *Optimize the system resourceFlashGet can use up the lowest system resources and will not influence your normal work or study.*Call anti-virus automatically FlashGet can call anti-virus automatically to clean viruses, spyware and adware after finishing download.*100% Clean, free.No adware and spyware. Easy to install and use.*increase the download speed and stability Flashget can increase download speed from 6-10 times. It uses MHT (Multi-server Hyper-threading Transportation) technique and optimization arithmetic and it.*SupportHTTP,FTP,BT,eMule and other various protocolsFlashGet supports HTTP,FTP,BT,MMS,RTSP and other protocols. It is seamless between protocols and there is no need to operate manually for download switch. The One Touch technique optimizes BT download and can automatically download target files after getting seeds information, hence no need to operate again. *Powerful files management featureIt supports unlimited categories. Each category is assigned a download saving directory. The powerful management feature can support drag and drop, adding and description, search, rename, etc.@4.01Mb 29E3FBD9A0A73E6B6ED3D76D4112DB8ANote:Sett as default download manager (including torrents)Google toolbar is not installed by defaultDrop Box is disabledPersonal note: Based on Rick's discontinued addon.Changelog: 3-October-08 Major registry cleanup. Edited October 23, 200816 yr by Gorki
October 4, 200816 yr Thanks I noticed gt.exe still resides in the program folder. Can it be remove totally? Edited October 4, 200816 yr by Geej
October 4, 200816 yr Author Geej said: Thanks I noticed gt.exe still resides in the program folder. Can it be remove totally?Yeah decide to leave it in case somebody decides to install it anyway. It's very easy to remove it...
October 5, 200816 yr Gorki said: Yeah decide to leave it in case somebody decides to install it anyway. It's very easy to remove it... Thanks for clarifying on this file as I'm not sure if this file will affect Flashget if I had it removed. Now removed.
October 21, 200816 yr @GorkiIs this Addon only with English language or is it the multi-language version.I would like if it's in german too.Thanks in advanceHuberer
October 21, 200816 yr Author Huberer said: @GorkiIs this Addon only with English language or is it the multi-language version.I would like if it's in german too.Thanks in advanceHubererAddOn is with English language ONLY,so it's not multilanguage. It's ONLY available in English for now, however some users are contributing and helping developer to add other language support available here ob FG boards.If you have language upload it and I'll see what can I do.
October 21, 200816 yr Thanks, I didn't know that there is only an enlgish version available.I read that there're requests for a german translation. Will wait for that.ThanksHuberer
October 21, 200816 yr Oh god, when have they updated to 2,0? You've releassed 2,1. Wooot, i love this proggy
