qwesta Posted September 30, 2008 Posted September 30, 2008 I have made many intergration Cds up to date but this one has taken me to the edge.After integration and test installation on Virtual box I get this "This application has failed to start because framedyn.dll was not found. Re-installing the application may fix this problem. Quote
ccl0 Posted September 30, 2008 Posted September 30, 2008 have you asked over in the nlite forum? http://www.msfn.org/board/nLite-f89.html Quote
ricktendo Posted September 30, 2008 Posted September 30, 2008 This is a addon issue, organize your addons by date and leave out the latest ones you have added to your session...then slowly add the latest addons two or three at a time until you reproduce this error...then find wich of those 3 are the cause of this errorThis is time consuming but you have to find the offending addon Quote
Geej Posted September 30, 2008 Posted September 30, 2008 I had this similiar problems some 2 mths back. As pointed by Rick, it is addon issue. For my case, it is sysoc.inf type addon (a few though, can't remember the exact program name) as silent exe type usually works better (and less likely to have issue).Good luck Quote
