gers_george Posted October 4, 2008 Posted October 4, 2008 I use Windows Remote Desktop Connection alot in my house to connect to the other computers in my house but I was wondering if there was a way to connect to my PC's from a computer that is not connected to my house but only using Windows Remote Desktop Connection. All my computers are connected to a router and still havent found a way to bypass it as all computers ip address would be set to 192.168.0.x which is local host on the router so you can't type that in on Windows Remote Desktop Connection off my network. Any help would be appreciated.Thanks Quote
Doubleeagle Posted October 8, 2008 Posted October 8, 2008 use your ip address you get from your ISP not your router Quote
gers_george Posted October 9, 2008 Author Posted October 9, 2008 use your ip address you get from your ISP not your routerip address is dynamic so its not possible to use ip address but their is a way to bypass this. Quote
Nomadturk Posted November 17, 2008 Posted November 17, 2008 Try Logmein.comWith it, you can access computers even behind proxies. Quote
