[Disconnected]Windows Live Messenger 9.0 Build 14.0.8064.0206
Windows Live Messenger 9.0 True Addon
Picture of the Program :
Download
Home Page: http://download.live.com/messenger
MD5: ec3c96d9e8ee20d8cecc720eb21a7eda
Note 1:
Now the Addon Appear in Windows Component
A Pic Of it Here
Note 2:
uninstall any older version of messenger before installing this one <<< Specially Older version
(Unless you used my own addon - I added An installer which would uninstall The previous installer automaticlly)
The Addon Is no longer working
Use OnePiece Addon here
or banners tool here
Or my Tool here
ChangeLog
6-3
Readded Last Version with WLdlog fixed
21-2
Fixed Wldlog.dll Removing throw Default Install
20-2
Updated To Build 14.0.8064.0206
Fixed Upgrade Error Or downgrade version problem
Fixed Typo
Added Remover For Wldlog.dll <<<it gets Removed after Restart
Added Sign-In-Assistant
Added Windows Live Upload Tool
Added Auto Uninstaller For Previous Version <<Works Only with my addon
Removed Unneeded Registry
Cleaned Up Inf
6-2
Updated The Inf
Added font installer in default install
added icon for Windows Live Communication
Fixed Typo
Cleaned Up Inf
Added commands to intergate The program into Windows Component during Default install
5-2(Beta)
I started a new Change log Coz this is a new inf
Updated To Build 14.0.8050.1202 ;left to add more fixes to The Inf
Edited by DaRk MaDnEsS
  • Replies 67
  • Views 29.9k
is this only for English version or..?
For now yes
i`m reuploading the files to fix some problems i found when i installed it live
so stay tuned
updated
sorry Media Fire Seems to have a problem
it gave me the share key and it deleted after it
so reuploading it
sorry for that
fixed The link to the Messenger
Hope you like it
upload an italian language please
well right now i`m not done with any other version
i need to download it`s files and see the different so i find the language file
and right now i think its msgslang.14.0.5027.0908.dll
so if you already got this version upload this file for me and i would see if its working
but right now other language but English are not available
I like your windows live suite idea of the parent to all the uninstallers...I just managed to fix this problem with my MSI svcpack spanish addons
Rick
ha! do you mind a German version too?
thx
this is not for Nlite Addon???
i can't see any entries_xxxx.ini
hmm sorry been tired in the few days
so i don't know what am i doing
so thx for informing me i`m reuploading
edit: new Link added
Updated!
add Svcpack Edition
This is a New Installer Uninstall is Fixed in it
  • 3 months later...
Updated !
This addon still beta Tommorw i will Realease the new finished Inf
This one works well on Live Install
Thanks DaRk MaDnEsS. I've been using the newest Live MSN a couple of days and I really like it.
Updated !
...I'll wait for tomorrow's, finished release , knewing that you make good add-ons ;)
Don't worry
the reason i uploaded the beta that it`s working quite well using A live install
almost all missing stuff is back to Default install
any way i`m almost done << just had to sleep a few hours to work again
couple of hours and it would be out
is wlm9 still beta? or is this a final release? i looked at the link and saw nothing about beta
edit: i mean the software itself, not your addon :P
Edited by ccl0
Hi ccl0
wel This is wave 3
i heared that there would be another version soon to fix the bugs in this version
then move to wave 4
so this is not beta nor the final version
there would be more until final
and Updated ! the inf now is my final
if any bug appeared plz report
Hi and thanx for this great work !
Could I use Your AddOn to try to make a french version from your job (with credits..)
It's almost done, I just want to know if it's a problem for you.
nop no problem
i think the different between my addon and the french would be in Lang Files
and in the Installer Product Code
so if any problem i`m glad to help
nop no problem
Thank you very much !
I've done this and add a line in the .inf for cosmetic : line 4283 : InfoTip ="Windows Live Call" otherwise there is location instead of Tip in start menu.
But it roxx !
Thanks DaRk MaDnEsS :D
just to inform every one
i`m almost done with upgrading the Addon
the reason i got so late that i`m Adding Sign In Assistant and Windows Live tool update
as well as fixing other problems and my net connection and i needed to read some stuff on the internet
i finished all bugs as well as typos yesterday
today i will do my tests and update it right away
thx for your patience
