Posted October 5, 200816 yr I am trying to make a addon that replace the OOBE, SYSDM, LOGONUI, WINNTBBU etc. in the i386 folderTHANKS.I have been replacing the files manually but want to make "Special XP Edition Addon" also for some reason when replacing the SYSDM, after rebbot it will not work. THANKS
October 5, 200816 yr Thats the great thing you dont need any code just use the entries.ini to add name version and stuff, leave it blank and zip your files with the ini and ur goodHere is a vista sounds replacement you will see what i mean http://www.wincert.net/forum/index.php?showtopic=1643
October 5, 200816 yr Author Thanks Rick, I will give it a try. I tried that way awhile back and had no luck. I will double check it again and try.
October 9, 200816 yr Author Thanks Rick, I will give it a try. I tried that way awhile back and had no luck. I will double check it again and try.No, luck. I tried to cabbed files and uncabbed files. the logonui and sysdm will no work.
October 9, 200816 yr Add this to the entries section for nLite and the RVMi to do it properly:Flags=ignorefileversions
