[AddOn] - Total Commander 7.04a (En,De,Bs,Hr,Sr, Ru)
Posted (edited)
Updated 13.10.2008
I corrected inf file. Now when you uninstall, then the folders will be deleted (thanks to Gorki ;) )
It includes following languages:
En (english),De (german),Bs (bosnian),Hr (croatian),Sr (serbian), Ru, (russian)
Default Installation Folder: %ProgramFiles%\Total Commander
Uninstaller is present
Uninstaller shortcut in startmenu bis present.
Added shortcut to KEYBOARD.TXT (Keyboar layout)
Scanned with AviraAntiVir 8.
I tested it only on a live system. You can install with Right click on TotalCmd.inf > Install.
MD5: BEC09E140FCCB7503212A95B36825E83
SHA1: C5EACC70A74AAC8E5A159349984FBD8464855C0C
CRC32: 05084013
Website: http://www.ghisler.com
####### HOW TO MAKE REGISTERED ADDON #######
If you want to install Total Commander with your Key, first open TotalCmd.inf with any text editor (like notepad) and then just remove ";" on lines 80 and 117, then rename YourKeyfile to real filename.
Example:
[SourceDisksFiles]
YourKeyfile.key=1
[TotalCmd.Files]
YourKeyfile.key
Info
When you uninstall, it deletes all files and Shortcuts, but empty main folder and empty Language folder (subfolder) stay there. I did't found solution for this, would be nice if someone could tell me why these 2 folders are not deleted.
Edited by N1K
Info
; Uninstallation part
[UnInstall]
EndPrompt =EndUnInsPrompt
RunPostSetupCommands=Just.In.Case
UpdateInis =sysoc.Edit
Cleanup =1
also add this section
[Just.In.Case]
RUNDLL32 advpack.dll,DelNodeRunDLL32 %16422%\%PROGTITLE%,8 ;This will take care for remaining folders :)
[sysoc.Edit]
%17%\sysoc.inf,Components,TotalCmd=*
since we add [sysoc.Edit] in .inf file we must do the same in .ini file otherwise it won't work.
[sysoc.Edit]
Updated: 13.10.2008
Now uninstallation deletes the folders too.
@Gorki
Hvala, sada sve funktionise ;)
For people that don't understand croatian, I just said thanks to gorki.
