NIM Posted November 23, 2006 Posted November 23, 2006 Since I'm still using CRT monitor, it's time to upgrade to LCD I've got two monitors that are my favorites and probably will decide for NEC, but also would like your thoughts, comments and suggestions..Thx..Product Description NEC MultiSync 20WGX2 - flat panel display - TFT - 20.1" Device Type Flat panel display / TFT active matrix Colour ( the image may represent the product of a different colour ) Built-in Devices USB Hub Dimensions (WxDxH) 47.1 cm x 20.2 cm x 39.2 cm Weight 6.3 kg Diagonal Size 20.1" - widescreen Dot Pitch / Pixel Pitch 0.258 mm Max Resolution 1680 x 1050 / 60 Hz Colour support 24-bit (16.7 million colours) Image Aspect Ratio 16:10 DELL monitor LCD 2007WFP 20'' TFT UltraSharp Wide 20.1 inch, Flat Panel LCD TFT (Active Matrix), Brightness: 300 cd/m Quote
WolfX2 Posted November 24, 2006 Posted November 24, 2006 i would say dell....but the NEC has better/more features...so go with the NEC Quote
NIM Posted November 24, 2006 Author Posted November 24, 2006 the problem is that this DELL monitors has the same price as this NEC here in Croatia, although it's much cheaper everywhere else.. You can see by the specs that NEC offers much more for the same price.. Quote
MGadAllah Posted November 25, 2006 Posted November 25, 2006 As long as DELL Always looks betterAs long as NEC Always has more featuresSO NEC always better then DELLLOL LAMO... Quote
NIM Posted February 11, 2007 Author Posted February 11, 2007 Just for an info, I bought NEC 20" Quote
Guest beemarin Posted February 11, 2007 Posted February 11, 2007 Although I hate Dell (grrrr), everyone that I know that has one of them swears by it.Have fun with your NEC! I still love my Samsung, though =D Quote
