maman Posted October 18, 2008 Posted October 18, 2008 OS: Windows XP/VistaCPU: Pentium 4 3.2 Ghz or AMD Athlon 64 3500+RAM: 1GB MB RAM or higher (Windows Vista requires 2 GB RAM)HDD: 10 GB free disk space or moreGraphics: 256 MB or higher (Pixel Shader 3.0, PCIe only) *DirectX: Version 9.0cRECOMMENDED REQUIREMENTSOS: Windows XP/VistaCPU: Intel Core 2 Duo, AMD 64 X2 5200+ or AMD PhenomRAM: 2GB MB RAM or higher (Windows Vista requires 3 GB RAM)HDD: 10 GB free disk space or moreGraphics: 512 MB or higher (Pixel Shader 3.0, PCIe only) *DirectX: Version 9.0cATIRadeon X1600 seriesRadeon X1800 seriesRadeon X1900 seriesRadeon HD 2400 seriesRadeon HD 2600 seriesRadeon HD 2900 seriesRadeon HD 3000 seriesRadeon HD 4000 seriesNVIDIAGeForce 7300 seriesGeForce 7600 seriesGeForce 7800 seriesGeForce 7900 seriesGeForce 8500 seriesGeForce 8600 seriesGeForce 8800 seriesGeForce 9500 seriesGeForce 9600 seriesGeForce 9800 seriesGeForce 200 series***NOTE: Laptop versions of these chipsets may work, but are not officially supported.NVIDIA GeForce 6000 series not supported.from www.gamespot.compretty high,huh?? I think my laptop can't handle this game well :sweatingbullets: Quote
MrNxDmX Posted October 19, 2008 Posted October 19, 2008 Umm, its weird that there is no dx10 requirement. But i'm sure that this game will rock Quote
Gorki Posted October 21, 2008 Posted October 21, 2008 Funny thing is that last weak I just installed Pro Street,and I did not like it that much like Underground. I hope Undercover brings up good old days Quote
Guest Posted October 21, 2008 Posted October 21, 2008 Funny thing is that last weak I just installed Pro Street,and I did not like it that much like Underground. I hope Undercover brings up good old days well under cover is the same idea as most wonted :sweatingbullets: which is surely better than pro street <<<< as i hope lol my lap top can hardly pass the minimum specification is the nvidia 8400M Gs supported? i hope it does Quote
Guest DennyMK Posted December 15, 2008 Posted December 15, 2008 I don't like Pro Street neither. Installed it once and after a couple of hours, uninstalled. I like Underground 2 and Carbon, Most Wanted is ranked on the 3rd place by me. Quote
