Posted October 18, 200816 yr :crying_anim02: Hello i am new to this forumhow to create a own logon screen and add it to XP cd like these.The easiest method :sweatingbullets: http://www.wincert.net/forum/index.php?showtopic=4599
October 19, 200816 yr Welcome to Wincert mate, nice to meet you. To create your own log on screen you can use Stardock Logon Studio. You can download it for 100% free hereTo integrate it with XP CD Setup (pre-installed) you can ask to Wincert Special Forum for Add on there or directly to thread that you told above (This Forum is for Windows Customization only - both Xp and Vista). Good luck. Cheers!
October 20, 200816 yr use stardock's Logon Studio to create Logon screen And u can convert it to logonui.exe i thinki dont know if this gonna workif you are done creating logon screen (must be logonui.exe) launch nlite and check the option hotfixes and update patch and then browse your created logonui.exe IT will make logonui.ex_ for u (it will replace the logonui.ex_ on i386 but i dont know if this gonna work
