thilakshan Posted October 27, 2008 Posted October 27, 2008 please helpHi i tried a slient install with nero 7.10 and i edit the cong and excluded all the things i don't need, i only included burning rom and nero vision. it installs perfectly fine without any error, but when i open to check it don't have nero vison or the ablility to burn dvd's. i teseted it with virtual pci have "WAREZ", and i tried to edit the config not to show to complete message, but every time during the runoncex the "WAREZ" installs fine but then shows the completeion notice, can some one show me how to install adobe cs3, i have adobe cs3 master edition but i only want adobe photoshop cs3 to install unattendedhow can i make only that program installthanks for ur help Quote
Guest Posted October 27, 2008 Posted October 27, 2008 (edited) Neronero liteadobeadobe cs3adobecs3silentofficeOffice 2000/XP/2003/2007 Slipstreamer, version 1.7.4 Office 2007, Unattended Setup Edited October 27, 2008 by mona Quote
thilakshan Posted October 27, 2008 Author Posted October 27, 2008 the thing about nero lite is that it doesn't have nero vision Quote
ccl0 Posted October 27, 2008 Posted October 27, 2008 if you want to know how to make addons for your pirated software i think you will have to figure out on your own. Quote
