Hi, i use the silent adobe reader 9. and it works fine with the installation and everything. but once all my runonce is finished i get an error saya
advance install error or something like that, but when i take adobe off the runonce i don't get that error no more, can some one help me out please
wht can i do to fix the problem, its a slient install so where would the inf file be, wold i need to extract the file, the ini file located inside the silent installer looks like this
;Adobe Installer External Configuration File: Abcpy.ini
;Main Section
;The (Product) key is a required key
[MAIN]
Product=Adobe® Reader® 9
AbcpyVersion=9.0
;OEM Installation Options
[OEM Install]
INSTALLDIR=
ALLOW_LOCKDOWN_BROWSE=YES
ALLOW_LOCKDOWN_MEDIA=YES
ARPHELPLINK=
ARPHELPTELEPHONE=
ARPNOMODIFY=
;ARPNOMODIFY=YES disables the "Change" button in Add/Remove Programs
;Launches - Set for any other applications you wish to launch
; 1. Define 1 or more custom section names -> MyLaunch
; 2. Enable your custom section(s) -> MyLaunch=YES
; 3. Set up your custom section:
; [MyLaunch]
; TYPE=EXE (Can be EXE or OTHER - default is OTHER)
; PROGRAM=C:\My.exe (can be null type is EXE and if included in commandline)
; COMMANDLINE= (add program arguments here)
; CHANGEDIR= (add working dir here)
; WAIT=YES (Can be YES or NO if type is EXE)
; PLATFORM= (Any delimited combination of the following:
; WIN_XP
; WIN_2K
; WIN_ME
; WIN_98
; WIN_NT4
; (delimiters: any printable char)
;--Launch Objects
[Launches]
MyLaunch1=NO
[MyLaunch1]
TYPE=
PROGRAM=
COMMANDLINE=
CHANGEDIR=
WAIT=
PLATFORM=
Edited by thilakshan
I have the same problem.
If adobe reader is installed svcpack style, it will give "advanced inf install failed. Reason: access denied" even if it is installed at runonceex it errors. I have to install it at runonce on the second startup.
I have tried using my own installer and RogueSpear's, doesn't seem to matter.
any help would definitely be appreciated.
AdbeRdr90_nl_NL.exe /sAll /rs /l /msi"/qb-! /norestart ALLUSERS=1 EULA_ACCEPT=YES SUPPRESS_APP_LAUNCH=YES"
Works fine @ cmdlines.
