thilakshan Posted November 2, 2008 Posted November 2, 2008 After i make the first shot and then modify my windows and take the 2nd shot.once compareing itt shows me all the registry the changed and been addedis there a way to make the txt file which is gives to a registry file so i can use that at unatteded instead of manually makeing the txt file into reg Quote
Guest Posted November 3, 2008 Posted November 3, 2008 After i make the first shot and then modify my windows and take the 2nd shot.once compareing itt shows me all the registry the changed and been addedis there a way to make the txt file which is gives to a registry file so i can use that at unatteded instead of manually makeing the txt file into reguse InstallWatch it`s much better than Regshot and it extracts as reg i just used reg Shot to compare filesi hope i helped Quote
