It's a dll file jetaudio register file extension with located in Program Files\JetAudio\JetFlExt.dll
I try to make an addon for jetaudio 7, everything went fine except the shell extension of the program. After several trials I figure out that this dll 's responsible for the shell extension. I register it manually and it works but how to make this via an addon.
Edited by eliteos
in the install section
add
RegisterDLLs=Dll.Register
and
make
[Dll.Register]
and add after it
16422,%ProgramFolder%,%dllFile%,1
that should do it
This should do it (OCEntry should be changed to whatever you have under [Optional Components])
[OCEntry]
OptionDesc=...
Tip=...
Modes=...
CopyFiles=...
AddReg=...
RegisterDLLs=ShellExt.DLL
[ShellExt.DLL]
16422,JetAudio,JetFlExt.dll,1
Hey Rick....
Using your example....
How would you un-register a dll when
uninstalling a program?
i will answer this one
use
UnregisterDlls=
just as simple as this
Yes use UnRegisterDLLs with the same section you used to Register them (it runs before DelFiles) example:
[DefaultInstall]
CopyFiles=...
AddReg=...
RegisterDLLs=DLL.Files
[DLL.Files]
16422,SubDir\SubSubDir,dllname.dll,1
11,,dllname.dll,1 ; if there is no SubDir leave that part blank
[Uninstall]
UnRegisterDLLs=DLL.Files
DelFiles=...
DelReg=...
As you can see by the example I use the same section to register and un-register one or more dll's
But sometimes UnRegisterDLLs will not work if you use advpack.dll to launch the uninstall section, then you have to use RunPreSetupCommands like this:
[Uninstall]
BeginPrompt=...
RunPreSetupCommands=DLL.UnRegServer
DelFiles=...
DelReg=...
EndPrompt=...
[DLL.UnRegServer]
"REGSVR32 /u /s ""%16422%\SubDir\SubSubDir\dllname.dll"""
"REGSVR32 /u /s %11%\dllname.dll"
