Posted November 7, 200816 yr Hello,im thinking of buying myself a computer for chrismas.and it has to be fast and powerful.the computer im thinking of getting is a dell computer: Dell XPS 420its really nicebut i was talking to my friend and he said why not make one from the start cause then you pick what you won't and it will run how you won't it to.he took me to a store near where i live and showed me some stuff.i found 2 Case/Bodys for my ideal computer. I like the 1st one better.CASE 1orCASE 2there was some good motherboards as well but i do not know which type i want to go for.AMD or Intel?they do Bundles:Bundlesi think the Quad Core Q6600 bundle is good it comes wih a 1GB memory and a Fan with it.then i looked at the AMD bundles and i don't know much about AMD Processor'sbut they looked good but as i said i don't know much about AMD Processor'sso i could use the help from all you guys cause this was my 1st place to come to for advice thank you for your help :sweatingbullets:
November 7, 200816 yr Let build a rocket I suggest you these:Case: Thermaltake Armor silent but if you want it to be more silent,you can change fans with ultra silent.Processor: Intel
November 7, 200816 yr What do you think about SAPHIRE ATI HD4850 or SAPHIRE HD3870 ultimate. (it is also my graphic card, and really good performance, cheap, you can look at it here)But 8800GT is really good choice Edited November 7, 200816 yr by ALtF4
November 7, 200816 yr What do you think about SAPHIRE ATI HD4850 or SAPHIRE HD3870 ultimate. (it is also my graphic card, and really good performance, cheap, you can look at it here)But 8800GT is really good choice Yer ATI are a good make and they look goodand i saw the 8800GT for
November 7, 200816 yr Yes, but buy between 512 MB-1 GB memmory And ı bought laptop Asus F8VA C1 I suggest this laptop too.It is really wonderfull.
November 7, 200816 yr Yes, but buy between 512 MB-1 GB memmory And ı bought laptop Asus F8VA C1 I suggest this laptop too.It is really wonderfull.thank you for your help. and yer im going to try for 512MB and get 2 of the 8800GT Edited November 7, 200816 yr by snakecracker
November 7, 200816 yr thank you for your help. and yer im going to try for 512MB and get 2 of the 8800GTNO, one is enough.. I have it and it's sufficient for all of the new games, especially with 4 gigs of RAM and quad processor. That combination shouldn't be expensive these days..Also, don't use crossfire or SLI technology 'cause you won't get more than 30-40% from other card when in SLI mode. For that money, better buy one newer card.
November 7, 200816 yr NO, one is enough.. I have it and it's sufficient for all of the new games, especially with 4 gigs of RAM and quad processor. That combination shouldn't be expensive these days..Also, don't use crossfire or SLI technology 'cause you won't get more than 30-40% from other card when in SLI mode. For that money, better buy one newer card.oh ok thanks N1K
November 7, 200816 yr oh ok thanks N1K I have ever use crossfire tecnology (ı am not rich as much to buy 2 card )As he said, you dont need 2 card.What about Nvidia Geforce GTX280?take a look and compare GTX280
November 7, 200816 yr I have ever use crossfire tecnology (ı am not rich as much to buy 2 card )As he said, you dont need 2 card.What about Nvidia Geforce GTX280?take a look and compare GTX280my mate has that and he has 2 of them he said they are really good. i might get one..lolthanks
November 7, 200816 yr But dont forget this.Tecnology is so fast.So we will never have best pc.For example ı had ati x1600 pro which is the best 2 years ago.Now it is so old card.I hope ı could tell clearly But ı am sure that you will had a rocket Good luck.
November 7, 200816 yr But dont forget this.Tecnology is so fast.So we will never have best pc.For example ı had ati x1600 pro which is the best 2 years ago.Now it is so old card.I hope ı could tell clearly But ı am sure that you will had a rocket Good luck.lol yer i know tecnology seems to be here and the best that same day then its old the next daybut thank you you've been a great help
November 9, 200816 yr Ok i got a picture of what is going to be inside my new computer Spec:700W X-Power ATX SLI PSUIntel Edited November 9, 200816 yr by snakecracker
November 9, 200816 yr Nice but ı think ASUS P5Q Deluxe, ASUS Maximus Formula or Asus Rampagne Formula colud be better on MB...Don forget your RAMs arent ordinary so be carefull to choose right MB Thermaltake CasesASUS Game MotherboardsASUS P5Q DeluxeBut ı want to repeat that again.It depends your choice And HDD could be Seagate 320 GB 7200 Rpm 16 MB cache.My personal idea is Seagate is best on HDD HIGH POWER is really good on power supply Edited November 9, 200816 yr by ALtF4
November 9, 200816 yr Nice but ı think ASUS P5Q Deluxe, ASUS Maximus Formula or Asus Rampagne Formula colud be better on MB...Don forget your RAMs arent ordinary so be carefull to choose right MB yer ok thanksill take a look at the MB's edit: thanks for the links Edited November 9, 200816 yr by snakecracker
November 9, 200816 yr ASUS P5Q Deluxe looks very good!it can go up to 16GB RAM! seems to be the one for menow... where to buy the thing.....lolthanks
November 10, 200816 yr ASUS P5Q Deluxe looks very good!it can go up to 16GB RAM! seems to be the one for menow... where to buy the thing.....lolthanksYou can try Microdirect.co.uk Asus P5Q Deluxe or Aria.co.uk Asus P5Q Deluxe As I live near Manchester then these are the 2 places that I tend to use for getting my PC stuff from as I can easily drive there since I am too impatient to wait the few days it takes to have them posted.
November 10, 200816 yr Ok i got a picture of what is going to be inside my new computer Spec:700W X-Power ATX SLI PSUIntel
November 10, 200816 yr My opinion:Thermaltake Case (better to be safe with well known manufacturer http://www.thermaltakeusa.com/Product.aspx...mp;ID=1819#Tab2Which ever ASUS MBO you choose, you'll choose good, my vote for ASUS.I would also go with Corsair modular power supply unit..620Whttp://www.silentpcreview.com/article692-page1.htmlAlso, I'd choose Corsair XMS2 or Dominator memory modules..I dont know corsair on power supply but about RAMMy choice is OCZ or Kingston HyperXBecause they have special cooling equipments.OCZ DDR2 RAMKINGSTON HYPERX RAM Edited November 10, 200816 yr by ALtF4
November 10, 200816 yr i love them Thermaltake Case there really nice but Can't Find a place where to buy them ill keep looking but ill try and get it off ebay (thats if my mum gets signed in to them)and im looking to get some memory special cooling equipments.they would run alot more better.
November 13, 200816 yr ok this is hows its looking now.the ASUS P5Q Deluxe is goodbut im going for the Asus P5K SE/EPUand im going to have the full 8GB RAMbut ill will start of with 3GB then add it everytime i get the moneyim also going to get a 320GB Hard Drive w/ a added cooling.also the RAM will have memory cooling.700W X-Power ATX SLI PSU im going with. the more power the better.im going to stay with this PC case as im going to add alot more fans to it.Gamer / Server PC Case with 250mm Fan. im going to have 2x 120mm Fans at the front.2x 80mm Fans at the back And the 250mm Side Fan.im going for the Intel Quad Core Q6600im thinking for going for the Nvidia 8800GTX 512MBbut ill keep on changing stuff as time comes..... Edited January 10, 200916 yr by snakecracker
November 13, 200816 yr HOLY CHIT!!! That many fans will sound like a helli all the time in your bedroom..
November 13, 200816 yr LOL it can also be used as a vacum cleaner...it will suck all the dust out of the room & into the pc
November 13, 200816 yr LOL it can also be used as a vacum cleaner...it will suck all the dust out of the room & into the pc lollet me guess too many?there 'ULTRA QUIET' as it states.loli could have 1 at the front.and then 2 at the back.lol
