FloatingNotes 1.3
FloatingNotes 1.3
1. Features
FloatingNotes allows you to place notes on the screen.
For the ease of use it allows customization as:
Half transparent (adjustable) notes on desktop
CountDown
Changeable background colors and size
QuickHide option to disappear the note for a few seconds and allow access the screen behind
Transparent text background to work with the screen behind
(Don't) Remember settings
2. Hidden Features
When clicking on the background color example in options it selects a random color from the default list
Running the program with argument '/ noreg' would prevent using of registry (saving / loading settings).
This may be done through the command line or with the shortcut that was provided alongside the exe.
3.Developer's Note
FloatingNotes was written in C #.
This is my first program in C # that was published.
It was created as a test to learn the language and it's features.
The idea was to create something small and simple, yet using the new advantages of C #.
4.About
FloatingNotes was made by TF ©.
All copyrights are reserved.
This program is a freeware, you may distribute it as long as you give me the credits.
5.Need Net 2.0 Framework.
Website
Website If Frist Link Not Worked
