Finally I installed Vista final 6000 and again I encountered an error in Help & Support. Every time I click on it a get error saying that file can not be found. :sigh:
It seems that there is an issue with xml extensions association if you install any xml editor like Dreamweaver in my case :shocking: .
Copy paste text below to notepad and name it fix.reg, run it and everything should work just fine (it restores default values in registry). :thumbsup:
[HKEY_CLASSES_ROOT\.xml]
@="xmlfile"
"Content Type"="text/xml"
"PerceivedType"="text"
[HKEY_CLASSES_ROOT\.xml\OpenWithList]
[HKEY_CLASSES_ROOT\.xml\OpenWithList\winword.exe]
[HKEY_CLASSES_ROOT\.xml\PersistentHandler]
@="{7E9D8D44-6926-426F-AA2B-217A819A5CCE}"
