Posted December 17, 200816 yr Can someone please explain what the difference is between the Addons? If I'm understanding correctly, an SVCPACK addon is an addon that is installed at T-13... I think. So, what exactly is a "True Addon"? And how would you integrate a True Addon using nLite for example? Also, how do INF files work in relation to addons?Just a few questions to increase understandability. Edited December 17, 200816 yr by Zoom7000
December 17, 200816 yr Hi and welcome to the Sitelook Svcpack Addon is installing the program throw silent command in a T-13Like Msgplus which can be installed silently using \Silent command True addon is integrating the addon in Xp cdif you open the Infyou would find commands to install the program in .... and to make a shortcut the inf contains the commands to tell the Windows Setup where and what to do the simply addon is like A cab file + Inf file the cab file contain the Prog Filesand the Inf got the commands to install the programi hope you understood me
December 17, 200816 yr True addons try to mimic how windows installs some programs, like notepad and other of its accessoriesINF files are basically text files that tell windows where to copy the files and what to add in the registry
February 17, 200916 yr So, are True Addons integrated in nLite using the same method?Yes, INF file is executed same way whether its nLite or Integrator. Hope that answers your question
