February 28, 201312 yr Geej, can you please also update this one to the latest version. Thanks. BTW, this version was ok for xp. Don't know if changes are needed for this one also, as you made for the win7/8 addon.
February 28, 201312 yr You should wait until the next version, because 1.3.1.636b seems rather buggy (It's a major release, now Everything use a service to access to the disk) and the change isn't needed for XP, only for Vista+ (because of UAC)
March 1, 201312 yr Author Geej, can you please also update this one to the latest version. Thanks. BTW, this version was ok for xp. Don't know if changes are needed for this one also, as you made for the win7/8 addon. Updated to 1.3.1.636b (.lng file updated as well) Note:I keep it simple. Not install as services. Setting does not store in user app dir. Cheers
April 18, 201311 yr Author Updated v 1.3.2.645b Also minor improvement by adding language localised support for French:If OS eng is ENU, .lng file is removed. everything.ini is set (localization=English)If OS is French, lang is set to french for everything.ini (localization=Français)Please feedback if things are wrong.Let me know if user want other languages to be included by letting me know the hex id of your language.Eg. .040C for french .0409 for English-US
April 19, 201311 yr Author Minor update for v1.3.2.645bBugfix for French language setting.Updated language fileAdd inf language support for German, [strings.0407]
April 20, 201311 yr Author Minor fix:Change inf page encoding to UTF-8.Match .ini language spelling with inf Added Spanish localization, [strings.0C0A].
April 21, 201311 yr A little typo error inside Evthing.inf:[Strings]T13ROE=SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnceEx\EverythingConfigDisplayProgram=SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\EverythingAppName=Everythingversion=1.3.2.644bThanks to change to: version=1.3.2.645b Regards Edited April 21, 201311 yr by myselfidem
June 18, 201311 yr Thanks for the info.x64 build installed: works fine, some new options are very handy, like double-clicking on path open it.
July 12, 201311 yr HiI have been using this app and your Addon for as long as you made it, but this current Addon breaks up the whole set up when integrated on a new CD I was trying to make.Believe me I use so many addon on my integrated Cd, but it took me some hell of work to figure out which Addon was the culprit (took ages to sort it out).do you have a previous on as I had deleted mine in the hope all was fine? or may be you can check on this AddonThank you and a nice day
July 14, 201311 yr Author HiI have been using this app and your Addon for as long as you made it, but this current Addon breaks up the whole set up when integrated on a new CD I was trying to make.Believe me I use so many addon on my integrated Cd, but it took me some hell of work to figure out which Addon was the culprit (took ages to sort it out).do you have a previous on as I had deleted mine in the hope all was fine? or may be you can check on this AddonThank you and a nice day I have recently tested under HFSLIP and it works alright. Dun know what is wrong right now at your side.Does it install properly if you perform a normal install? If normal install is okay, try re-wrap using 7z-sfx, turning it into silent installer.I might have old copy of it. I need to search for it. What was your previous version that works?
July 14, 201311 yr it does install quite well normally and that is what I did after a new XP installation.it seems not to work when integrated into CD as Addon though. NB i had to fall back to an old version 121452 and that works perfectly Edited July 14, 201311 yr by qwesta
